  • masonis1
    If you cant control it 👍👍
    • 1173
    #571
    Well got everything in. Now the problem is the flex rod is too long. I cut the brass tub down. How do I cut the flex and blue tubing around it?
      • 7651
      #572
      I believe you said you have a dremel.Cut the flex cable down to the motor shaft.Take the collet off the motor and don't forget to leave some space between the back of the strut and the drive dog.About the width of the flex cable.
      Brass tube looks to be a good length.Just enough room to remove the collet.
        • 7651
        #573
        Originally posted by masonis1
        ok. got the pilot hole drilled. will move up the a bigger bit and so on. i will try to get this done as fast and good as possible. hah
        Don't be rushing at any of this Mason.Measure and square up 5 times and drill/cut once.
        • masonis1
          • 1173
          #574
          Ok sounds good. On my drive dog, there is a spacer about the size of the flex thickness. Would this work or do i still need to add more space, if i add too much, the nut for the drive dog is gunna start hitting the rudder
            • 7651
            #575
            I am hunting for a pic but the space is for the flex as it shrinks when it spins up.new strut 031.jpgThere you go just click on it to blow it up.
            • masonis1
              • 1173
              #576
              Now how do i mount the stand to the transom?
                • 7651
                #577
                I would use some wood screws from the inside.More measuring and contemplation.You're doing good. Did you put a bend in the brass tube?
                • masonis1
                  • 1173
                  #578
                  Now i think the hard part is over but im kinda guessing thats still to come...
                    • 7651
                    #579
                    You've got to make sure the tube is straight inline with the strut at the back with a slight bend up to the motor.If there is a sudden bend at the strut the flex could break there and then there goes the shaft,drive dog and prop never to be seen again.
                      • 7651
                      #580
                      I better get a couple of boats ready.It may be nice Saturday and I may not have to work
                      • masonis1
                        • 1173
                        #581
                        Lucky you and i dont understand.. so it will be flat out at the prop but curved by the motor?
                        • masonis1
                          • 1173
                          #582
                          Is this ok?
                          • h2o 1
                            • Sep 2011
                            • 770
                            #583
                            That looks good,just make sure everything is centered before u screw it down
                            • masonis1
                              • 1173
                              #584
                              How should i screw it down? I have the center lines just need to know what to do?
                              • h2o 1
                                • Sep 2011
                                • 770
                                #585
                                Wood screws,from inside the transom into the standoff.Everything has to be square Mason
