I found the pic.So the mounting surface or the strut is 1" behind the nose?
I would think an extra 1/4 to 3/8 should do it as you can have the brass stuffing tube sticking out of the transom till it mates with the nose of the strut.If it is not fully locked into the strut you should have some adjusting room.Does this make sense to you? And how tight does the brass fit into the nose piece?When speed isnt the option, change your waysComment
That's OK.So you should drill your hole for the tube in the transom.Drill a pilot hole first.Then you can put the tube in the nose and decide where the stand off mounts to the transom,and the distance.I guess you could mount the strut to the stand off.Comment
