  • masonis1
    If you cant control it 👍👍
    • 1173
    #1306
    Alright we will, we'll I used some Traxxas outputs with brass bases and plastic tips and they were strong
    • masonis1
      • 1173
      #1307
      Well it's winter and I'm tearing the boat down and rebuilding her. ImageUploadedByTapatalk1353377539.359977.jpg
      At this point I have a support/battery tray mounted in the back to stiffin the transom up.
      Also, I removed the motor mount screws to the hull and filled them. I am now going to epoxy the mount in.
      This should get less drag on the bottom of the hull from the screws.
      Next I will be reshaping the stand on back. I have a spacer but it points down and causes prop mounting problemsImageUploadedByTapatalk1353377722.538174.jpg
      I'll also be adding some wood supports where I have existing mounting posts in the hull. Two over the motor to keep it down, and I will be making a bigger platform too.
      • seehuusen
        • Apr 2012
        • 96
        #1308
        looking good Mason :) Any hardware changes? Or just re-jigging the current gear for a better performance?
        I'm nearly done with mine now :) Just blew my ESC, so I need to either solder up my smaller ESC or get another 120-150 amp ESC... Spewing, coz I was hoping for the maiden voyage today :p
        • masonis1
          • 1173
          #1309
          I'm just trying to make it more reliable to I can go faster and not worry about a wreck.
          • seehuusen
            • Apr 2012
            • 96
            #1310
            cool mate :) I take it you're getting some new paint on there as well? After filling in the holes...
            • masonis1
              • 1173
              #1311
              Nope I've painted this thing too many times
              • seehuusen
                • Apr 2012
                • 96
                #1312
                LOL, I agree, after a while it gets a bit old
                I got mine out for the maiden voyage today, cheers for your help and kind words :)
                Cheers Martin
                • masonis1
                  • 1173
                  #1313
                  Looks good
                  • seehuusen
                    • Apr 2012
                    • 96
                    #1314
                    how's the rebuild going mate? got any pics of the new setup? :)
                    • masonis1
                      • 1173
                      #1315
                      Actually working on it now!
                      Got the stand straight. Lot of cutting and filing!
                      Got the brass tube in and stuffing tube in getting mounted, found where y major leak was from! The space around the brass tube was pretty big and the silicon wasnt as good as I thought inside stopping water from getting in. But I filled it and it's ready.
                      I'm going to try to make some more platforms for the inside to stiffen an mount stuff!.
                      • seehuusen
                        • Apr 2012
                        • 96
                        #1316
                        coming up a treat mate :)
                        Before I put mine back in the water, I've gotta do some leak finding too... I'd like the boat to be near 100% water proof, it sorta sucks having half a cup of water inside the boat after each run... Plus I'm sure it's not good for batteries etc to get wet LOL
                        • masonis1
                          • 1173
                          #1317
                          Well another update.
                          Worked quick today!
                          Ready for running, weather permitted.
                          It's a mess but that's a t180 and a 3s... 3s is more fun.
                          While the 2s I have fits perfectly along the rear, like I said, 3s is more fun!
                          • masonis1
                            • 1173
                            #1318
                            Just tested and got a minute of video. It's fast but the flex shaft came loose and was just spinning in the connecor, don't loose them tho
                            • seehuusen
                              • Apr 2012
                              • 96
                              #1319
                              weather permitting... more like "the minute I can get my arse down to the pond" hahaha I get ya :D
                              Are you going to post up the vid?
                              Will you be putting all that wiring/ Rx setup into a radio box or something?
                                • 7673
                                #1320
                                What kind of coupler is that there Mason?Do you think you just didn't tighten it enough or...
                                I have had to make the fingers in them close more.And if it spins on the shaft too many times you will have to do that as it wears the shaft down
