The prop off my miss geico
It should do well. Get some vid..............we need fresh vid!!!!!NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
I haven't ran a boat since my last video and that was the blast. Now with a 3s I will run this boat and the MG. the MG will be tested on 5s a little and I will fine tune the strut or try to.When speed isnt the option, change your waysComment
3s test. Wtch the whole thing through, to see the jumpWhen speed isnt the option, change your waysComment
Just trim your rudder to the left a bit so when you get to full throttle it runs straight, no way around that in an overpowered small boat...........its torque steer.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Well my cousin just told me he tried his blast on 3s, same set up as mine almost. Well he said it was way too fast an could never get to full throttle, the drive shaft got hot, broke the coupler from motor to drive shaft. But I think a Traxxas steel output should fix that and an easier finger will help.When speed isnt the option, change your waysComment
