  • masonis1
    If you cant control it 👍👍
    • 1173
    #1276
    The prop off my miss geico
    • Make-a-Wake
      FE Rules!
      • 5557
      #1277
      It should do well. Get some vid..............we need fresh vid!!!!!
      • masonis1
        • 1173
        #1278
        Yep I'll try today or this weekend.
          • 7673
          #1279
          I was wondering how you were doing bud. Boats going good?
          • masonis1
            • 1173
            #1280
            I haven't ran a boat since my last video and that was the blast. Now with a 3s I will run this boat and the MG. the MG will be tested on 5s a little and I will fine tune the strut or try to.
            • masonis1
              • 1173
              #1281
              Just tested on3s, too fat. Never got to ill throttle and it jumps out if the water and rides flat!! I think it's as fast or faster than my mg. I got a good video of it.
              • masonis1
                • 1173
                #1282
                3s test. Wtch the whole thing through, to see the jump
                • masonis1
                  • 1173
                  #1283
                  Hey guys, if you watch the video you might notice the boat pulling way hard to the right. Chine walk I guess. How can I adjust this?
                  • Make-a-Wake
                    FE Rules!
                    • 5557
                    #1284
                    Just trim your rudder to the left a bit so when you get to full throttle it runs straight, no way around that in an overpowered small boat...........its torque steer.
                    • masonis1
                      • 1173
                      #1285
                      Hahah I like knowing I have the power but too much isn't good
                      • masonis1
                        • 1173
                        #1286
                        Going to try and test the boat on 2s today and then I'll run on 3s for fun again. I'll try some video today
                        • masonis1
                          • 1173
                          #1287
                          No running today. Servo was messed up.
                          • masonis1
                            • 1173
                            #1288
                            Well my cousin just told me he tried his blast on 3s, same set up as mine almost. Well he said it was way too fast an could never get to full throttle, the drive shaft got hot, broke the coupler from motor to drive shaft. But I think a Traxxas steel output should fix that and an easier finger will help.
                              • 7673
                              #1289
                              Is that a drive shaft or flex?
                              • masonis1
                                • 1173
                                #1290
                                It's a shaft. Just a rod
