I believe you said you have a dremel.Cut the flex cable down to the motor shaft.Take the collet off the motor and don't forget to leave some space between the back of the strut and the drive dog.About the width of the flex cable.
Brass tube looks to be a good length.Just enough room to remove the collet.
Ok sounds good. On my drive dog, there is a spacer about the size of the flex thickness. Would this work or do i still need to add more space, if i add too much, the nut for the drive dog is gunna start hitting the rudder
You've got to make sure the tube is straight inline with the strut at the back with a slight bend up to the motor.If there is a sudden bend at the strut the flex could break there and then there goes the shaft,drive dog and prop never to be seen again.
