  • masonis1
    If you cant control it 👍👍
    • 1173
    #601
    I have a little park where i tested before about a mile away. Kinda small but good for testing.
      • 7673
      #602
      For the steering,keep the rod as straight as possible with no drastic bends.Check that the throw is smooth and doesn't bind up.
      • masonis1
        • 1173
        #603
        Where should i drill the hole and how big should it be?
        • izcain
          • Mar 2012
          • 274
          #604
          Thats lookin better and better mason
          • masonis1
            • 1173
            #605
            Thanks to you, its looking great. Your parts rock... Ha thanks again. I hope i can get this beast sitting on the water soon.
            • izcain
              • Mar 2012
              • 274
              #606
              Do you have a small boot or something for the rod to pass thru the transom for sealing? You may want to look at getting one.
              • masonis1
                • 1173
                #607
                The one mark sent had a big boot on it.
                • izcain
                  • Mar 2012
                  • 274
                  #608
                  Once you are getting close to I can't stress how important it is to do a bathtub test better to know before going to the pond and losing the whole thing to a small leak lol
                  • masonis1
                    • 1173
                    #609
                    I dont understand how you use that or put it in.
                    • izcain
                      • Mar 2012
                      • 274
                      #610
                      oh right on as long as you have a way to seal it off
                      • masonis1
                        • 1173
                        #611
                        How to i place the boot?
                        • izcain
                          • Mar 2012
                          • 274
                          #612
                          What does the boot look like. I might use a small piece left over from that stuffing tube and make the hole and seal that piece of tube to the hole that way it gives you something to clamp the boot onto for the rod to pass thru.
                            • 7673
                            #613
                            You can drill a small hole through the transom in line with the arm of the rudder.There is a hole for a rod or linkage to go through on the rudder right.
                            • masonis1
                              • 1173
                              #614
                              Ok. Im too tired. Im lost. Ill just figure this stuff out tomorrow. Anymore tips. Lemme know. Hah
                              • masonis1
                                • 1173
                                #615
                                There is a hole for that. I will put the piece i got from mark on tomorrow.
