The Voracity tuning thread
  • Keagan-Z06
    • Mar 2016
    • 970
    #496
    • Voracity
      • Dec 2015
      • 31
      #497
      How can i best het the new teflon liner in? I only get it halfway before it gets stuck...
      Do you also get grease coming out of the part where brass tube goes in the black piece? Dont know how its called
      Thx
        • 8750
        #498
        Thx
        It needs to be longer than what you need. Then clamp one side with vise grips and slightly stretch it. When you stretch it, the diameter will shrink but it will go back to its original size shortly after. Wait a couple minutes after you slide it in. Then cut the excess.
        • Voracity
          • Dec 2015
          • 31
          #499
          Ok thanx. Another question: what should the timing be on 4092 1730 with seaking 180 setup?
          • arrover
            • May 2015
            • 322
            #500
            I believe that I have been running 0 degrees of timing with the 4092.
            ProBoat Zelos 36 Twin, Voracity 36, Impulse 31, Stealthwake 23, and HobbyKing Flowmaster Videos
            • Voracity
              • Dec 2015
              • 31
              #501
              Hi guys, how did you connect the seaking esc in the boat? With tie ribs or bolted somehow?
              • shua
                • Apr 2015
                • 479
                #502
                My sk180 is just double side adhesive Velcro off to the side of where the stock esc was mounted.
                • shua
                  • Apr 2015
                  • 479
                  #503
                  And that is an extra cap bank and BEC in the original esc location.
                  • arrover
                    • May 2015
                    • 322
                    #504
                    My Turnigy 180 is mounted with Velcro in the same spot as Shua's.
                    • Voracity
                      • Dec 2015
                      • 31
                      #505
                      Ok guys. First test with 4092. Everthing worked. Stock prop.3,75 degrees timing. Top speed was poor but it looked like when the boat comes on speed it held back. Perhaps because of 25-50c gens ace packs? Not enough power? Better batteries are underway (turnigy 45-90c).
                      Also the boat leanes to the right? Also on medium speed.
                      Nothing can go wring with the Cables from esc to motor right?
                      Any thoughts?
                      • arrover
                        • May 2015
                        • 322
                        #506
                        What prop? I believe I run my GPS on the opposite side as the ESC for a little weight balance. That might help you. How are your trim tabs adjusted? Where are your batteries on the battery trays?
                        • Voracity
                          • Dec 2015
                          • 31
                          #507
                          The originale prop. The boat leans to right so putting weight opposite the esc seems to make it worse? My esc is in the place where the stock esc is. Batteries are way back. Strut al little more to the wet side. Trim tabs little up.
                          Could batteries be the cause? Did you ever used 25c succesfully?
                          • Voracity
                            • Dec 2015
                            • 31
                            #508
                            Is 0,7 cm distance between prop and strut to much?
                            • arrover
                              • May 2015
                              • 322
                              #509
                              .7 cm might be a little much but that probably isn't the problem. You want around 4mm gap between the strut and drive dog. The biggest problem is probably the prop. You need to go to a larger prop. It also sounds like you may have the boat running to wet because the strut is to low. Yes, I was wrong, my GPS is on the right side and would make your problem worse. My tabs are level to VERY SLIGHTLY down.
                              • Voracity
                                • Dec 2015
                                • 31
                                #510
                                M0re testing today. Speed was up to 48 mph with 45c batteries, but not what it should be, other batteries go into lvc very fast (setting 3 amp), timing 0. Octura x450, a little Sanded but not balanced yet. Torque rol to left, a little compensated by lowering right trim tab, maybe putting esc more to left (like arrover) is better, mine is in original position. Boat flips from left to right side on speed. Other problem left turning is very poor.. Dont know why.
                                Maybe extra water pick-up at transom has bad influence?
                                Also the spray is way less as original. I would expected more spray because of the bigger prop?
                                More torque at accelaration but top speed poor. Boat seems running to wet.
                                So more testing to do... . Any thought/tips more than welcome!
