  • Chris VB
    • Jul 2016
    • 21
    #1051
    3/8" worth of threads, no loctite just lock washer. Checked them after my runs, haven't budged. Just make sure you crank em down good.
    • Chris VB
      • Jul 2016
      • 21
      #1052
      Polishing
      Polished everything up to a mirror finish, already notice a small boost in performance :) (Stock props in box)
      • Yellow
        • Jan 2016
        • 81
        #1053
        That's a cool photo! I hope to get a gps soon too. Perhaps you can post a video of that bad boy?
        • Team Lucas
          • May 2016
          • 300
          #1054
          I am sorry if I posted things that went wrong on stock Zelos 36. I thought that's what this thread is about, not only mods to boat and out come, but to make alert of problems that can happen and how to correct it.
          Zelos 36 stock 68 mph
          • Yellow
            • Jan 2016
            • 81
            #1055
            Nothing wrong with that.
            • Chris VB
              • Jul 2016
              • 21
              #1056
              Nothing at all. Any tips or feedback is always helpful!
              • Erroneous
                • Apr 2016
                • 451
                #1057
                Call it what you will but. A lil blue locktite serves me well. Dropping $50 props with tons of time in them into the unknown depths is no bueno.
                • Chris VB
                  • Jul 2016
                  • 21
                  #1058
                  I've been trying to load a 19 second video of the new props in action but it says invalid file type. I'll try from my laptop tonight.
                  • Keagan-Z06
                    • Mar 2016
                    • 970
                    #1059
                    That looks real nice!
                    • Keagan-Z06
                      • Mar 2016
                      • 970
                      #1060
                      Yup, I cry a little inside every time I pull the trigger and boat goes nowhere. lol. I start calculating in my head, there goes another 20-30 bucks plus S&H plus 3-4hrs of S&B.
                      • Mxkid261
                        • Jun 2015
                        • 734
                        #1061
                        Use loctite. I only run a bullet with a dab of loctite on all my cables and I've never lost a prop
                        • Team Lucas
                          • May 2016
                          • 300
                          #1062
                          SHAFT CORRECTION.jpgwell add me to the " to much in a rush stupid list ". I ruined the stock right flex shaft do to greasing and installing wrong, as in (L) (R) expanded the cable. Wondered why I lost speed. have new shafts from ose only because they are a little longer at the threaded end so bigger props are no problem. Here is a example I made to help people that get confused on the way (L) and (R) shafts work.wrong.jpgcorrect.jpgTHIS IS INCORRECT, NEW POST SHOWS CORRECT WAY
                          • paulfromtulsa
                            • Nov 2013
                            • 211
                            #1063
                            Originally posted by Team Lucas
                            well add me to the " to much in a rush stupid list ". I ruined the stock right flex shaft do to greasing and installing wrong, as in (L) (R) expanded the cable. Wondered why I lost speed. have new shafts from ose only because they are a little longer at the threaded end so bigger props are no problem. Here is a example I made to help people that get confused on the way (L) and (R) shafts work.[ATTACH=CONFIG]145588[/ATTACH][ATTACH=CONFIG]145589[/ATTACH]
                            It also depends on what way your props are turning. Are yours setup to turn inward or outward?
                            • Keagan-Z06
                              • Mar 2016
                              • 970
                              #1064
                              You da man!
                              • Chris VB
                                • Jul 2016
                                • 21
                                #1065
                                Thanks , took a few hours per prop. I use a fine rubber sand disc for my dremel to get the "Chrome" look then buff again with buffing wheel and compound and finally autosol for brilliant shine
