  • Keagan-Z06
    • Mar 2016
    • 970
    #901
    Originally posted by kfxguy
    I wanted to let you guys know there a different option if you want to run 6s and not have to fool with 4 batteries and not quite as much weight.....
    Do you think the added weight will compensate a bit for not being able to go all the way under the bow?
    • Banzee
      • Mar 2012
      • 186
      #902
      Personnally i prefer 2 x 6s in parallele !!
      • Keagan-Z06
        • Mar 2016
        • 970
        #903
        Kfxguy bullied me into getting the very same 6s packs! lol
        • Erroneous
          • Apr 2016
          • 451
          #904
          97.6WH Beasts.
          • Banzee
            • Mar 2012
            • 186
            #905
            That is a good thing , cuz i got 6 x 6s 2650mah that are 7 years old and i can drive my zelos with , they don't have the punch of new ones , but they are good enough to have fun !! I put 3 in my boat in parallele and zoom !
            • Banzee
              • Mar 2012
              • 186
              #906
              Originally posted by erroneous
              97.6wh beasts.
              ????????????????? Mph ??
              • Erroneous
                • Apr 2016
                • 451
                #907
                Last view of her before the new blue/green chameleon paint job starts. image.jpg
                • Erroneous
                  • Apr 2016
                  • 451
                  #908
                  Wow, ok then, now uploading from my crapple ibone doesn't only flip 90* but goes full inverted.
                  • Erroneous
                    • Apr 2016
                    • 451
                    #909
                    (W)att. (H)ours
                    • Keagan-Z06
                      • Mar 2016
                      • 970
                      #910
                      It happens! Can't wait to see it! I'm kinda digging the no decals look. If I repainted mine I want the word Zelos in the Fightercat font!
                        Yes. I didn't run mine under the deck anyway.
                        • Mxkid261
                          • Jun 2015
                          • 734
                          #912
                          Water should shoot a good 16-18 inches out.
                          I'd be shocked if you have a 18" water stream Lol
                          • Mxkid261
                            • Jun 2015
                            • 734
                            #913
                            Travis are you planning on a motor swap I noticed you have yours out in that picture.
                            • Rafael_Lopez
                              • Jan 2015
                              • 470
                              #914
                              How would this work with regards to what Rafael mentioned with the purpose of the cooling. He stated somewhere in this thread that you wont see water spraying 6-8" out the outlets because it is designed to keep the water just enough to cool the motors and ESC efficiently. DO NOT QUOTE me on that. lol
                              Do not use Y splitters. Water, like electricity will choose the path of least resistance. Putting Y's in place will only cause more heat issues.
                              How hot are you guys running that you need so much water running through your electronics? If you have heat issues, it's for a reason. Running more water through the system is just a band aid, the issue causing the heat is still there.
                              Rafael Lopez
                              Product Developer-Pro Boat
                              • Keagan-Z06
                                • Mar 2016
                                • 970
                                #915
                                My motors in particular got real hot to the point when I opened the hatch there was some smoke. Not its not on fire smoke but smoke nonetheless. First thing I thought was I had clogged lines. Not the case! I thought maybe the motor and shaft alignment. I double checked that a few minutes ago and it's all good as of now. I have free turns from both shaft when powered and no vibrations like I did before I changed my bearings. Will give it another go this afternoon and report back.
