  • fweasel
    master of some
    • Jul 2016
    • 4285
    #2401
    Good color combo
    Vac-U-Tug Jr (13mph)
    • Jrock609
      • Sep 2018
      • 8
      #2402
      Thanks. Doing the zelos 48 next lol really need to stop crashing my boats.
      • Raydee
        • May 2007
        • 1603
        #2403
        For the guys that painted your hulls, did the stock graphics come off without peeling the paint with them?
        Sent from my SM-T320 using Tapatalk
        Team Liquid Dash
        • fweasel
          master of some
          • Jul 2016
          • 4285
          #2404
          I have not done any painting, but the decals I removed came off just fine. I ran a hair dryer over the hull for a minute or so just to get things pliable.
          • Raydee
            • May 2007
            • 1603
            #2405
            Ok good, looking to do my own graphics but was worried about the paint getting pulled up with the factory graphics.
            Team Liquid Dash
            • Jrock609
              • Sep 2018
              • 8
              #2406
              I had no issues taking the graphics off. Didn’t even warm them up first but I also wasn’t worried about the paint since I was going to sand it down anyways. But if your worried about your paint then use a hair dryer to warm up the glue.
              • Jrock609
                • Sep 2018
                • 8
                #2407
                • Jrock609
                  • Sep 2018
                  • 8
                  #2408
                  Had one of my stingers wear out. Easy cheap quick fix. Use a 1/4 bullet for synflex fitting. AFA5E49D-E0DD-4922-B100-5614892FB2B5.jpg8154FE8F-AA3F-45B4-A276-B22FA6914E2A.jpg
                  • robw
                    • May 2014
                    • 58
                    #2409
                    well, I just ordered one of these and after reading all of this thread, looks like I will be doing a few upgrades before it goes on the water, that's next year then!
                    • lt130th
                      • Apr 2014
                      • 858
                      #2410
                      Well, I finally got around to finishing my carbon mounts. I gave my template for these to stratus, last year. By December, he'd made a set, and installed them. So, I'm a little behind on my build. Anyway, it's finally time to put it all back together with the Leo 4082's, and post this baby up in the for sale section, because I have waaaay too many boats, now. LOL.
                      • Jrock609
                        • Sep 2018
                        • 8
                        #2411
                        I just got on this forum and haven’t gone threw much info yet. But those motors don’t look stock😂 nice boat
                        • lt130th
                          • Apr 2014
                          • 858
                          #2412
                          Originally posted by Jrock609
                          I just got on this forum and haven’t gone threw much info yet. But those motors don’t look stock�� nice boat
                          They're 1600kv Leopard 4082's. Really an economy motor - not exotic, but reliable & makes ok power. A TP motor would be slightly better, and a Castle/NEU would be much better. I don't think this hull is worthy of motors beyond those. I had a plan to build the first 100mph Zelos 36, which involved a completely impractical setup. It likely would have either destroyed the hull going airborne, or caught fire (hence the use of the inexpesive Leopards, in case they were lost to Davey Jones' Locker). I was willing to go there, though. Since starting this build, however, I've not had a lot of time for boats and I have like 15 right now. So, I'm going to complete all my unfinished builds and sell off all but a few select hulls. I'll let the next owner try for the triple-digit crown.
                          • fweasel
                            master of some
                            • Jul 2016
                            • 4285
                            #2413
                            [ATTACH=CONFIG]162110[/ATTACH]
                            [ATTACH=CONFIG]162111[/ATTACH]
                            I literally sat down last night and started making templates for the same mount. Got contact info for "stratus"? Would love to get another set cut out.
                            • lt130th
                              • Apr 2014
                              • 858
                              #2414
                              Are you looking for someone to mill the plates & send them to you, or do you just want an accurate template?
                              I've spent a lot of time trimming and test-fitting these plates to get them just right. The template I sent Stratus didn't have any of the holes for the motor shaft or screws, and were the general shape to start with. I told him they would probably need some trimming/sanding since each hull is going to have irregularity. I can send you an updated template of these finished mounts if that's all you need. I found that the stuffing tubes were not placed with high precision, so I made the holes in mine specific to the locoation that each flex shaft exited the stuffing tube. It's your call on the holes. You can cut temporary cardboard or styrene plates with the holes, from the template, to test fit before cutting the carbon plates. Then, at least you'll have the motor screw hole template to place where needed if your stuffing tubes don't line up the same as this hull. I'll PM you this evening when I'm back in my office.
                              • fweasel
                                master of some
                                • Jul 2016
                                • 4285
                                #2415
                                Templates would be great! My hull already has quite a bit of reinforcement, so the internal dimensions will be different than yous, not to mention the production irregularities.
