  • kyoshosp2
    • Jun 2018
    • 39
    #2371
    also it has ran what seems to be hot .. i cant hold my finger on the cooling can hot.. i temped after getting home couple miles away . motors 142 esc 118 and bateries 146.. i cleaned cooling passages .. but the esc are new out the box from horizon . my stock ones had a issue that was warrantied . so do i need to set the timing in them? i bought the esc control box too .
    • wbuisch
      • Jun 2018
      • 3
      #2372
      Hello, I just purchased a Zelos 36 put in 4 batteries they were each 3Sa batteries took one quick run turned around came back did not even hit half speed it caught wind blew through the air and cracked the hull in half.
      Proboat it was nice enough to replace it but indicated they don’t warrantee against crashes which I guess I understand so my question is I need to build some sort of an airfoil or air wing to put on the front to keep the nose down as I love the boat but I fear that I won’t make it thru the summer.
      Anyone have any tips or links to parts that I could bolt on to this boat to keep it grounded?
      Blackjack 29
      Zelos 36
      Rockstar 48
      • fweasel
        master of some
        • Jul 2016
        • 4286
        #2373
        Air dams have their place, but in stock trim, you don't really need one on the Zelos. What you do need is a good setup. Have you measured and adjusted the position of both struts and made sure they were tightened down securely as outlined in the manual? Other factors like unfavorable water conditions and wind speed can also contribute to easy blow overs.
        Vac-U-Tug Jr (13mph)
        • Hardstyle
          • Jul 2018
          • 17
          #2374
          Here's one future owner of the Zelos 36, just placed an order.
          Im looking OSE's shops for spare/upgrade parts. What are the must do upgrades for this boat? I got some good advice in other thread to get breakaway screws for the rudder for spares, but what else now that im "shopping". Balanced and sharpened propellers are on my list too. Im gonna keep the electrics stock for now. Still haven't decided what lipo configuration im gonna choose, but 6s for sure. 2x3s or 4x3s or 2x6s lipos. I read that optimal balance is reached with 4 packs. Any suggestions or should I just go which feels right? My idea is to get 2 running sets so 8 packs feels quite pita if going for 4x3s packs.
          • kyoshosp2
            • Jun 2018
            • 39
            #2375
            Get the ose flex shaft savers so you don’t loose a shaft and prop if the collet loosened up , you can get some smc 7400mah 3s lipos and have more run time . The boat runs better I find on 4 batteries . Running on 2 3s only gets the adapters hot !! 6s packs don’t usually fit under the deck so you limited on boat stability I find . Also I say smc batts cause they have a 90c and up rating cause when you prop it up it’s gonna be more load on everything and you don’t wanna puff packs or have other issues .. also get a night tq waterproof metal gear Servo .. and while some say not needed I’d get the dual pick up rudder and cool the motors separate from the esc ..
            • Hardstyle
              • Jul 2018
              • 17
              #2376
              Thanks kyoshosp2! Didn't know there's such thing as flex cable saver. You seem to have good knowledge of the boat. How much there's room under the deck and the battery tray?
              SMC lipos seems to be out of the question as they don't ship internationally. Im thinking ordering all the lipos and charger from Hobbyking but there's no 90C rated ones in correct config..
              I didn't realize there's no pick up at the rudder. You are referring to this http://www.rcboatbitz.com/index.php?...3#prettyPhoto?
              • kyoshosp2
                • Jun 2018
                • 39
                #2377
                That’s the rudder ..try hrb lipos . 6000mah .. on eBay or amazon .. 6s is to thick to slide under front deck , Ive only seen one set do it and were a low mah rating which kinda negates using them to me ..
                • Hardstyle
                  • Jul 2018
                  • 17
                  #2378
                  Ok, ordered the rudder plus new better flex drive assemblys.
                  I found Floureon lipos from Ebay while I was looking HRB's. Anybody has used them in boats? Got a bit mixed feeling about cheap lipos in general when looking different forums for experiences. The thing with them is that the C ratings could be anything and it's on the user to find it out. Are the hobbyking lipos legit?
                    • 9488
                    #2379
                    FYI all LiPO batteries, the labels are misleading, none of the C ratings are correct no matter how much you pay for the pack
                    The hobbyking HD60C are a decent value
                    • kyoshosp2
                      • Jun 2018
                      • 39
                      #2380
                      I ran some flyer on in a single .. I find the twins have higher amp draw so I’d stick with a wider used pack name ..
                      • Hardstyle
                        • Jul 2018
                        • 17
                        #2381
                        Ok, thanks! I ran my rc car with A123 Li-ion's, Lipos I don't have so much knowledge. Maybe I will discuss these more in the Battery thread..
                        Any idea how much one motor can draw amps in Zelos?
                        Edit:.
                        Well I made compromise. Got 2x6S HRB 6000mah and 4x3S Turnigy HD 5000mah packs. Thanks kyoshosp2 for the HRB lipo tip, Ebay has good prices for them. Now it will be painful couple weeks to get all the parts and the BOAT in my hands...
                        • Hardstyle
                          • Jul 2018
                          • 17
                          #2382
                          Almost done! Still missing Dasboata's 1716 props... dang customs
                          New servo, dual pick up rudder and changed the cooling lines for larger ID. Also re-route the ESC's, dunno if that's better or worse. Usually you shouldn't fix anything that isn't broken...oh well.
                          About the gap between the drive dog and the strut. How it should be measured? Because the motors axle moves 1-2mm inside the motor and it affect the whole drive system.
                          I noticed quite some vibrations at the hull when tested the throttle on a bench, is it normal? Of course short period of time, just to make sure everything was working.
                          By the way is CRC's silicon grease good for the flex drive? It resist heat and water, and it doesn't brittle rubber/plastic.
                          • dasboata
                            • Dec 2010
                            • 3152
                            #2383
                            [ATTACH=CONFIG]160475[/ATTACH] [ATTACH=CONFIG]160476[/ATTACH] [ATTACH=CONFIG]160477[/ATTACH]
                            do I have you on my list ?
                            • Hardstyle
                              • Jul 2018
                              • 17
                              #2384
                              I don't believe I am, what list are you referring to? Sorry Im new in this forum.
                              Thanks for hooking me up with the props im that Finnish guy. But now those are held in customs and of course im leaving vacation today.
                              • martin
                                • 2887
                                #2385
                                Boats run out of the water with no load on the prop will sound like a bag of spanners.
