  • Keagan-Z06
    • Mar 2016
    • 970
    #1621
    Just got back from the lake. The boat is wa wa wa at 1mm down.
    • Yellow
      • Jan 2016
      • 81
      #1622
      Wa wa wa?
      • Keagan-Z06
        • Mar 2016
        • 970
        #1623
        Lol, nose bouncing up and down. I'm using 6s Revos, I don't think trimming down is helping, maybe I need to go back to 4 packs to get the weight up front.
        • fweasel
          master of some
          • Jul 2016
          • 4285
          #1624
          I ran 70mph on 2 3S revo packs installed all the way forward, 447 props, struts at 4mm. When I got the boat back together and ran it again on the ABC 1814 props with 4 3S packs (mounted to the stock trays), it was very floaty and was bouncing too. That setup only ran 65mph because I could barely keep the throttle pinned. To be expected as I changed just about everything but the trim angle, and had no time to tune further.
          Vac-U-Tug Jr (13mph)
          • Keagan-Z06
            • Mar 2016
            • 970
            #1625
            Will try that the next outing. The Revos sure do have some kick to it. I'll continue playing with it. I took the Daytona out as well so I shared my time between those two.
            • Team Lucas
              • May 2016
              • 300
              #1626
              Originally posted by Rafael_Lopez
              Mini40Man, you boat looks unrecognizable, nice job! Good job on the mod too.
              I think it's all a mater of choice. Most custom builds use under hull pick ups which have been proven many times to work well and also provide a very scale look; personally I don't like the look of visible water lines which is why I designed the boat this way. My 93mph Zelos 36 runs 4 under hull pick ups with no issue, but maybe at that speed water doesn't have a choice but to move up the pick ups, lol.
              I've not been made aware of anyone calling in to report having lost electronics due to lack of cooling, but I'm glad there is an option out there for those of you who feel the stock cooling is insufficient.
              Rafael, you designed a terrific boat hands down! However while zooming into pic's of me coming out of turns and straightening out I noticed that the port side pickup is not in the water, and may not be in the water through the entire turn?? I have not burned anything up while running suggested voltage so it is not a problem for the boat, but I like consent water flow. I'm going to try a rudder pick up. At full throttle around turns, the boat tends to "slide" so maybe a little longer rudder will help as well for my type of driving..ie..full throttle... lol.
              Zelos 36 stock 68 mph
              • banixj
                • May 2012
                • 107
                #1627
                Brand new props arrived just today!
                TFL Hobby CNC 4714 props!
                60usd...
                I will do some test and some shooting on next sunday if weather will be good...
                my target speed is at least 63mph... 70mph would be better...
                HPR 115 kevlar bulletproof @90mph, MHZ Rapid carbonfiber, Bingo Race Minieco
                Futaba AIR TX/RX system with telemetry
                • Team Lucas
                  • May 2016
                  • 300
                  #1628
                  Nice props. Are you running stock electronics ? and 12s total?
                  • banixj
                    • May 2012
                    • 107
                    #1629
                    stock electronics, 2x 3S in series
                    i'm sure that props are too large for summer running...
                    for this winter i hope they will be ok!
                    if the props are good in quality i will purchase a medium size for the summer... 43, 44 or 45mm
                    • banixj
                      • May 2012
                      • 107
                      #1630
                      new props installed...
                      now they're taking a rest...
                      waitin 4 sunday!
                      • fweasel
                        master of some
                        • Jul 2016
                        • 4285
                        #1631
                        waitin 4 sunday!
                        [ATTACH=CONFIG]148307[/ATTACH]
                        Those props are going to need some sharpening, but I'm not sure what one sharpens velvet with.
                          • 9488
                          #1632
                          60usd...
                          [ATTACH=CONFIG]148301[/ATTACH]
                          Looking forward to your run!
                          keep us posted
                          • banixj
                            • May 2012
                            • 107
                            #1633
                            one question about the prop nyloc nut size: is it a normal M5 or is it a 3/16 10-24 nut?
                            • dasboata
                              • Dec 2010
                              • 3152
                              #1634
                              3/16 shaft ? 10/32 .thread 187 ,,3/16" diameter
                              • banixj
                                • May 2012
                                • 107
                                #1635
                                can you please write a link for the nyloc nut? colored if possible...
