Try pushing your batteries forward. Running two or four? If 4 try cramming the 3rd and 4th along side of the ones in the middle. In stock trim I even pulled the foam rods and crammed little bolts in them and stuffed em back in. "Lost 9mph"?.. Corrosion in your motor connectors?Zelos 36 stock 68 mphComment
as far as I know, can only use Spektrum.Zelos 36 stock 68 mphComment
Yee-haw.....finally got my stock Zelos up to 72mph with a lot of help from tips and info you guys posted. Ran it with 12s 5200mah, OSE upgraded prop cables and s/b ABC 1814 props.
The main issue is with how hot the motors got with the water pick-up. Waiting to hear how Travis dealt with this issue and testing he was doing with micro pump pick-up.Comment
My motors got to 150f yesterday which is hotter than I like but from what I understand they will still live. Watch the video I posted, I wouldn't run it like that again with those props, it runs a little warmer than I'm ok with. The escs only got to 129f-130f32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Rafael Lopez
Product Developer-Pro Boat
My Facebook https://www.facebook.com/profile.php?id=100010183246751Comment
Trying to change bearings on my motor. Remove 6 head screws. Now what? Just pull on the shaft?Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
Do I need to remove the bottom screws as well? Hope not as those suckers are rather rusty and I'm pretty sure all won't budge.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
Still at it, can't figure how. It seems easier to open from the bottom. I was under the impression the top can be replaced topside and the back at the bottom side.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
Got it out! The top portion is threaded!Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
For others who may have to do this at some point. Here is how I did it.
1)Loose all 6 screws (don't remember the size needed to remove)
2)Place motor in a vice (may not be needed but mine was a pain)
3)Used a needle nose pliers to fit in the holes at the top (One in each hole across from each other, I believe there are 6, any 2 should work)
4)Expand pliers so it is touching the outer ends of the holes (Basically at this point you would be able to hold up the motor by just doing this if it wasnt in the vice at this point)
5)I used a adjustable spanner on the needle nose pliers and started turning (I needed some WD40 to persuade it)
After a few turns it should come loose. Upon inspection, my top bearings were completely done! No little balls could be found! I hope this helps others, there may be a tool that makes this easier to remove but this is MY experience and that's what I had to do to get it done! (At work)Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
Hey fellas, I made a "Zelos fast list" for everyone here, check it out and feel free to make suggestions.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
