My 2 cents on this hatch chat. I LOVE that with stock screws that it keeps water out with out using hatch tape. I been upside down for 8 to 10 minutes or more, and very, very little water leaked in, if any. Unless you like taping hatch down all the time, wouldn't mater much on the 4 corner attachments. I would keep it stock, and/or better. Just my 2 cents.Zelos 36 stock 68 mphComment
After picking KFXguy"s brain on his tool used to get the motor mount tight I have came up with a solution I wanted to share with whoever is having a hard time getting them tight with 2.5mm L wrenches. I use a 1/4 inch flex ratchet, with 1/4 inch socket with a 2.5mm Allen bit in the socket. It works Awesome!!! See picture
20170415_214642.jpgTFL Zonda (124mph), Miss Geico Zelos 36 (108mph), Veles 29 (91mph), Zelos Twin 36 (90mph), Miss Geico 29v3 (83.5mph), Sonicwake 36 V2 (83mph), Blackjack 42 (81mph), TFL Pursuit (79mph), UL-19 (75mph), Sonicwake 36 (73mph), Motley Crew (47.5mph), AquaCraft Rescue 17Comment
Hit my new record today 68.5MPH with 2 Venom 3s 50C 5200mah.
Still adjusting the Struts / lipo position, and still need to solder up some adapters to run 4 x 3s up front.
Struts were set at 2mm gap (4mm gap is the recommended stock setting)
MPH:68.5
Props: Dasbota S&B ABC 17/14 17Deg
Electronics: Stock
Lipos:2 x Venom 3s 5200mah 50C
Originally posted by MADRCER
I am having major heat in the stuffing tubes in my Twin and the shafts are discoloring and getting hot. I had them greased real well and I don't know what is going on. see pictures of the stuffing tubes. Are they supposed to have a bend in them middle ways or should they be perfectly straight? I took both motors out to make sure they were aligned straight with shafts and they were. The shafts slide in very easy and line up good. Motor mounts are very tight also and haven't moved. This was the first run with this boat. Any help would be greatly appreciated.
Vac-U-Tug Jr (13mph)Comment
My work on the inside of the hull is done.Fully reinforced with 2x 160g carbon almost up in the front of the nose and the sides also and a third piece only on top of the tunnel from the back to almost the last electronics tray mount,i removed all of the mounts( which on my hull was a really pain because they used so much glue from the factory) unfortunately i couldn't the motor mounts at least not with out doing damage to the hull so i left them there.Resin with chopped CF in the nose tips and the front join,where the stingers mount is also fully reinforced and i glue the nuts in there so when you need to remove and remount the stingers is a 2 min job now with out the need to use the 5.5mm socket drive any more.I used an extra 70g resin at the end to cover any imperfections on the inlay and because i like that glassy finish,need to sand it now to make it smooth but kinda cba now maybe some time in the future will do.Overall the hull is solid as a rock now and i dont have to worry anymore about flips and stuff especially when the motors and escs are going to be replaced which the strength will be needed!
20170416_201225.jpg20170416_201235.jpg20170416_201243.jpg20170416_201251.jpg20170416_201305.jpgGenesis 36", Zelos Twin 36"Comment
[ATTACH=CONFIG]150967[/ATTACH]32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Blew a motor this morning. Debating a new motor/esc setup or a new boat at this point. Had it in series (73mphPeakGps). Abc1915s. Upgraded shafts. Is it time to move into something bigger with heavier electronics or use the zelos and crank it up in electronics and dial in the timing, etc...
Ive read this whole forum over the course of a few months. Any updated information/recommendations would be highly appreciated.
Dan the Fireman/ChicagoComment
Dan the Fireman/Chicago32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Today i received my flexes from OSE i have a question thow,what alen number do i need to unscrew the drive dogs??i thought it was 1.5mm but its not... its smaller is the .050" the one i need?some one who have them already if can confirm pleaseLast edited by stratus; 04-21-2017, 07:24 AM.Genesis 36", Zelos Twin 36"Comment
