  • Team Lucas
    • May 2016
    • 300
    #1846
    Originally posted by Boaterguy1000
    I have ordered 2 no leopard 4082 x2 motors,
    What is the easiest way to change motors due to restricted access to the allen screw nearest the outside of the hull.
    Has anyone put these motors in Zelos 36, if so how did it perform and what props were used, thanks
    I have found its easier to remove the mount with motor intact, then swap motors and reinstall the mount
    Zelos 36 stock 68 mph
    • Boaterguy1000
      • Sep 2016
      • 18
      #1847
      Ok Team Lucas thanks
      • REDLINE1
        • Jul 2016
        • 199
        #1848
        Got a chance to run my Wohlt wire drives for the first full run today. I put them in last fall and never got a chance to really get a good run because I was having esc problems. Ran good today got 67 mph w 4 battery's wire drives worked well after about a 10min run mostly speed runs back and forth with some slower cruising in between. Zero water leaking it. I did remove the struts and remount with silicone sealer before installing the wire drives but I'm not using any cap seal on the stuffing tube up by the motor.
        Other thing which I don't know if will be an issue with extended use is when I install them I have to use a hook to lift the wire slightly up to get it to go into collet So because there is a slight end in the wire when installed there is some downward pressure on the collet end of the motor shaft
        • banixj
          • May 2012
          • 107
          #1849
          Today i'm so happy! Thanks to brand new 6S lipos! My personal record is now increased!
          MPH: 69 (good number) but real is 68.75....
          Prop: TFL CNC 4714
          ESC: Stock with timing 7.5
          Motor: Stock
          Batteries: 2x Zippy Compact 3300mAh 6s 60C
          Mods: Polished shafts
          Temps:
          Air: 21C 70F
          ESC: 45C 113F
          Motors: 50C 122F
          Next step: ABC 1715 prepped by an italian guru then HD shafts!
          My target is 75mph! i hope to don't fry all during summer....
          HPR 115 kevlar bulletproof @90mph, MHZ Rapid carbonfiber, Bingo Race Minieco
          Futaba AIR TX/RX system with telemetry
            • 9488
            #1850
            Nice man!
            Batteries match the boat :)
            • banixj
              • May 2012
              • 107
              #1851
              Nice man!
              yeah! thanx!
              • stratus
                • Dec 2016
                • 110
                #1852
                Originally posted by banixj
                [ATTACH=CONFIG]150832[/ATTACH]
                Prop: TFL CNC 4714
                Motor: Stock
                Temps:
                Air: 21C 70F
                ESC: 45C 113F
                Motors: 50C 122F
                Hope you break the 75 soon :) btw what run time you got with those 3300 mah?
                Genesis 36", Zelos Twin 36"
                • banixj
                  • May 2012
                  • 107
                  #1853
                  i hit lvc after 5 min... enough for me with 2 lipo sets!
                  • Team Lucas
                    • May 2016
                    • 300
                    #1854
                    Have a question w/o going back pages.....I been seeing in list, some have polished shafts. How do you polish a flex shaft?
                    • banixj
                      • May 2012
                      • 107
                      #1855
                      i can describe my way to do it: synpol cream and dremel with felt cap on it...
                      oxide come out, specially where there's ontact with bearing sor others...
                      obviously this treatment must be done on the "not flex part" of the axle...
                      i use synpol cream with paper too on my mini eco rigid wire shaft...
                      • REDLINE1
                        • Jul 2016
                        • 199
                        #1856
                        I polished the shafts on my wire and cable drives. Use a power / cordless drill, chuck the motor end of the cable or wire . Take a piece of fine emry folded between your fingers put a little oil on the shaft start the drill while holding the shaft between your fingers with the emry. Then I go back over with a soft cloth with mothers or flitz polish and drill looks like a mirror when done
                        • fweasel
                          master of some
                          • Jul 2016
                          • 4288
                          #1857
                          I put the flex cable in a drill and spin the entire thing while polishing the flex cable with sandpaper. I can't remember if I used 400 or 800 grit wet/dry. I know where it is in the drawer anyways.
                          I use Mother's metal polish on the prop shaft portion with a soft rag.
                          Vac-U-Tug Jr (13mph)
                          • Mxkid261
                            • Jun 2015
                            • 734
                            #1858
                            I also just chuck it up in a drill and use some 4 or 600 grit sandpaper
                            • Prodrvr
                              • Jul 2015
                              • 701
                              #1859
                              See, I knew I did mine wrong. I put some valve grinding compound on the flex, then ran it back and forth in the stuffing tube about 1 1/2" with the drill on full speed. Then cleaned everything and repeated the process with Flitz polish. Spins good, still hear the scratchy sound though while spinning it. I might have to get a can of brake cleaner.
                              • Erroneous
                                • Apr 2016
                                • 451
                                #1860
                                Same here. Flexxes in a drill but I started with a 3m 320 grit then 600 then 2"x2" polishing pads from Amazon. Carefull with the foam polishing pads if you use them. Too much pressure or too fast on the drill they will start to melt. Shafts are nice and shiny. Heres the pads. https://www.amazon.com/gp/aw/d/B00B3...?ie=UTF8&psc=1
