    I was thinking last night, those props I had on there are the lowest pitch that abc has. I could go up one step and probably get 70 out of it and the electronics would still likely tolerate it.
    • Mxkid261
      • Jun 2015
      • 734
      #1907
      Wow impressive. Those are 4050's correct?
      • Keagan-Z06
        • Mar 2016
        • 970
        #1908
        Good job Travis
        • baller69
          • Aug 2016
          • 45
          #1909
          great job guys thats awesome.i too plan to run my twin cordova 2700 kv on 4s for testing then if all goes well i will go to 6s and if still well 8s per motor. yes each 2700 kv motor is built to handle 8s in this boat for a total of 16s but i have to start at 4s as all u know to make sure esc and battery temps and still also motor temps all are in check.just have to find a good area here in toronto ontario to find a good water source to run on!!
          • Mxkid261
            • Jun 2015
            • 734
            #1910
            Shouldn't be that hard to find a spot to run it. Make sure to get a video or its maiden.
            • baller69
              • Aug 2016
              • 45
              #1911
              i am gonna forsure get a video i just dont know a good spot where i live so i live in oshawa ontario canada so if anyone knows a good spot resonably close that would be great oi also want to text out my lehner powered and custom done also zelos 48.it is awesome as well cant wait to try both.the 48 will run a 1650 lehener 3040 on 10s.cant wait!!!!!!
              • baller69
                • Aug 2016
                • 45
                #1912
                here is a few pics of the zelos 48.i called both these projects sink or swim rofl!!!!
                • Mxkid261
                  • Jun 2015
                  • 734
                  #1913
                  You should probably cut that stuffing tube shorter so you can wipe grease off the flex cable before it goes into the collet
                  • baller69
                    • Aug 2016
                    • 45
                    #1914
                    ok thanks will do. :) !!!!!!
                    • Team Lucas
                      • May 2016
                      • 300
                      #1915
                      Hey all...I can not get over 68 mph w/o blowing over and have lowered struts to lowest point and there both not even, not close. I know every hull is different, so I'm thinking hull is screwed, knowing and measuring the out drives measurements, to the hull bottom. I also checked the drive attachments, think my drives or the hull?
                      Zelos 36 stock 68 mph
                      • Tamelesstgr
                        • Jun 2014
                        • 1516
                        #1916
                        Is that a Carbon Wrap?
                        NEVER SATISFIED RACING
                        Fine Design 32 V-Hull 4082+6s
                        • baller69
                          • Aug 2016
                          • 45
                          #1917
                          it has been gold carbon fiber hydro dipped.cost about a 100 bucks to do on my boat.i have gotten alot of this hydro dipped.it is very cost efective.if you look up hydro dipping on youtube u can see how its done and the process is actually really awesome!!!!!!!
                          • fweasel
                            master of some
                            • Jul 2016
                            • 4287
                            #1918
                            What do you mean the struts aren't even? Are you not able to use a straight edge across the last two ride pads to take a vertical measurement to the bottom of each strut and adjust both sides so that measurement is equal?
                            As for blowing over, how many batteries, what capacity, and where are they mounted in the hull? What props?
                            Vac-U-Tug Jr (13mph)
                            • Tamelesstgr
                              • Jun 2014
                              • 1516
                              #1919
                              Interesting, how durable is the finish?
                              • ChevyPrerunner
                                • Jun 2015
                                • 205
                                #1920
                                Great job on that one Travis wow on 4S!!
