Thanks I will do that :-)
Hi guys,
I'm preparing mine for the summer but had an accident with the zelos last year that I'm fixing at the moment.
My boat submarined and hit some rocks at the bottom of the lake though it was pretty deep. 3-4 meters. I am repairing the crack with epoxy but the paint is screwed up at the front of the boat.
I'm thinking about a complete new paintjob.
What do you think, sand the old paint from the boat completely and use carpaint? or what is the best way to do it?
Thanks in advance, I've been trough the thread the past year and really learned a lot of you guys!
Happy boating to you all.Comment
Hi Guys.
Just got my zelos OSE flex cable today. But I wonder if the lable on the cable is wrong. The red label says right side I think its wrong ???
D29F0BCA-276B-4848-AFEA-15A79FDD3EBF.jpgComment
The cable with the "R" on it needs to be installed in your left side strut (since that motor should be rotating to the right when you run it) and put the other one in your right side strut. The "R" doesn't mean it's for the right side, it means it's a "right rotation" flex.TFL Zonda (124mph), Miss Geico Zelos 36 (108mph), Veles 29 (91mph), Zelos Twin 36 (90mph), Miss Geico 29v3 (83.5mph), Sonicwake 36 V2 (83mph), Blackjack 42 (81mph), TFL Pursuit (79mph), UL-19 (75mph), Sonicwake 36 (73mph), Motley Crew (47.5mph), AquaCraft Rescue 17Comment
Thanks Madrcer I was also confused about that label .The cable with the "R" on it needs to be installed in your left side strut (since that motor should be rotating to the right when you run it) and put the other one in your right side strut. The "R" doesn't mean it's for the right side, it means it's a "right rotation" flex.
This is not correct. In stock form, the props on the Zelos spin inwards. That puts the the cable marked with an R on the left/port side of the hull.
This photo is worded properly, but the position the cables are laid on the table next to one another is misleading. They should not be install in your Zelos as pictured here. As previously stated, the cable marked with an R gets installed on the left/port side of your hull. When both installed, the winds of both flex cables will make a ^ pattern, pointing towards the bow.Vac-U-Tug Jr (13mph)Comment
