Have someone experienced the motor on Zelos Twin burned. After a few minutes, one engine stopped working. And there was heavy smoke from it. ESC was not hot and cooling system not blocked. do not really understand why it is burnt, Should the ESC not be hot if water did get through. ??
Have someone experienced the motor on Zelos Twin burned. After a few minutes, one engine stopped working. And there was heavy smoke from it. ESC was not hot and cooling system not blocked. do not really understand why it is burnt, Should the ESC not be hot if water did get through. ??32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
That explanation still has a bit of mystery. If the motor is bound up by the flexes, it will pull a lot more current, so the ESC should be hot, unless it has a very high de-rate... It sounds like a winding failure, but that should pull high current too.. Sometimes it’s hard to know exactly, when it comes to electricity. All you can do is replace it, and triple check everything going back together.Comment
Did you flip the boat any? If so that throws them out of alignment. I speak from experience. Not guessing, mine was smoking when I brought it in and noticed the motors shifted. They can do it even if you didn’t flip. The mount is a poor design in my opinion. Good idea, but it should have a slot to keep it aligned. I’m pretty sure it was just in a bind slightly.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Did you flip the boat any? If so that throws them out of alignment. I speak from experience. Not guessing, mine was smoking when I brought it in and noticed the motors shifted. They can do it even if you didn’t flip. The mount is a poor design in my opinion. Good idea, but it should have a slot to keep it aligned. I’m pretty sure it was just in a bind slightly.Comment
Will these motor be gode for Zelos. and can the Stock ESC handle the. [ATTACH=CONFIG]157936[/ATTACH
Specs:
RPM/v: 1700kv
Poles: 4
Max voltage: 22.2v (6S)
Max Current: 84A
Max Watts: 1800w
Resistance: 0.0094ohm
No Load Current: 2.9A
Can Diameter: 36mm (actual motor diameter)
Can Diameter inc. Water Jacket: 44mm
Can Length: 60mm
Shaft Size: 5mm
Weight: 270gIMG_8797.jpgIMG_8797.jpgComment
You'll need to swing a lager diameter prop if you install a replacement motor with a lower kV motor to maintain a similar speed. That's an over simplification of all the factors involved, but something to consider. If you're looking for new motors with not a lot of other changes to be made, if any, the new Dynamite DYNM3831 are awesome and plug and play. They're more efficient than the originals and the stock ESC's can handle them, on appropriate sized props.Vac-U-Tug Jr (13mph)Comment
You'll need to swing a lager diameter prop if you install a replacement motor with a lower kV motor to maintain a similar speed. That's an over simplification of all the factors involved, but something to consider. If you're looking for new motors with not a lot of other changes to be made, if any, the new Dynamite DYNM3831 are awesome and plug and play. They're more efficient than the originals and the stock ESC's can handle them, on appropriate sized props.so I think I go whit and other brand.
IMG_8965.jpg IMG_8959.jpg IMG_8961.jpgComment
The newer style motor are much better.
https://www.offshoreelectrics.com/pr...od=hh-dynm3831
LarryPast NAMBA- P Mono -1 Mile Race Record holder
Bump & Grind Racing Props -We Like Em Smooth & WetComment
