  • stratus
    • Dec 2016
    • 110
    #2236
    Originally posted by lt130th
    Originally posted by fweasel
    Nice work. Those new mounts should add some rigidity to the sides of the hatch opening as well.
    The only other thing I'd change would be to put some 90* nipples on the motor cooling cans so that you can orient the top outlet as close to 12 o'clock as possible. The one on your right motor isn't that far off, but your left motor outlet is really low. The more water you can keep filled into the jackets, the better.
    Agree with you 100%.When i place an order for something new the 90* nipples will also be in that order for sure now as for the left water jacket unfortunately it just dosen't move..i tryed to move it so it will be at 12 o clock but at some point i was feeling that something is going to break so i prefered to just leave it like that.
    Genesis 36", Zelos Twin 36"
    • fweasel
      master of some
      • Jul 2016
      • 4287
      #2237
      Once you get some mineral deposits on the O-rings, they can definitely get locked in place over time. I've found that if I bolted the old L shaped motor mounts on and placed the mount into the jaws of a bench vice, I was able to rotate the cans by hand and clock them into the position I wanted. I suppose a little heat from something like a hair dryer might not hurt either.
      Vac-U-Tug Jr (13mph)
      • stratus
        • Dec 2016
        • 110
        #2238
        Took the motor off today again mounted that on the old motor mount grabed it on the vice,used a hair dryer to heat it for like 10-15 mins and then tryed to turn it...lol no way!!I start to believe that this think is glued or something.Anyway i am going to leave it like that for now.I learned in the past that if something don't want to come out and i am keep on trying it allways end up bad lol
        • Revolt Flash
          • Aug 2015
          • 437
          #2239
          I have used a little 70% Isopropyl Alcohol around the orings before to help loosen the can on the motor.
          • fweasel
            master of some
            • Jul 2016
            • 4287
            #2240
            Very wise! Maybe try the alcohol idea Revolt suggested. I bet the saltwater is not helping you on this project.
            • stratus
              • Dec 2016
              • 110
              #2241
              I will defiantly give this a try soon hoping it will help thanks for the tip! Btw I start to miss my zelos decals (i had them removed) any one knows where we can get just the decals? I can't find them anywhere..(sorry for the off-topic)
              • fweasel
                master of some
                • Jul 2016
                • 4287
                #2242
                I've never seen the decals available separately, only already installed on new replacement hulls. I bet someone could make new ones from vinyl though. Try contacting monojeff.
                • vinnyp
                  • Mar 2017
                  • 283
                  #2243
                  Ever since I put in those 3930 motors, I have been concerned about the stock Zelos motor mount ripping out. These motors are 40mm x 68mm . Some 5mm wider and 12mm longer than stock. Regardless of how tight I make those 2 little screws in the rear mount, the motors would move around during some of the acrobatics this boat took. I know acrobatics are not what we are looking for, but inevitably it will happen. I searched for a front mount that may work, but didn't find one that I thought would work and be accessible. So, I came up with this idea. I ordered the rings from OSE, I made up the plates myself. The bottom plate will get epoxied and glassed in place in the hull. The plate and ring on the motor stays with the motor. Once the motor is slid into place, the 2 get bolted together. The motor can still be aligned by the movement between the 2 plates, as well as movement between the ring and the bracket. It will take a bit of doing, however, I feel that once I get it aligned, it will be the last time I have to align it.
                  • fweasel
                    master of some
                    • Jul 2016
                    • 4287
                    #2244
                    I think that will definitely solve your movement problem Vinny. Bottom plate looks like maybe it's a little beefier/heavier than needed? I would imagine the weight really won't matter. I'm just used to seeing a lot of minimal design and carbon plate when it comes to rear motor supports.
                    • vinnyp
                      • Mar 2017
                      • 283
                      #2245
                      You are correct. The bottom plate is much beefier than needed. However, I needed to take up the space between the hull and bottom of the motor. I also need something that can be bolted in while the motor is tucked in the hull. As you know, space and maneuverability is at a premium in this boat.
                      • fweasel
                        master of some
                        • Jul 2016
                        • 4287
                        #2246
                        true, function dictates form in this scenario.
                        • vinnyp
                          • Mar 2017
                          • 283
                          #2247
                          I got to finish up the mounts for the 3930's in my Zelos. They worked well and easy enough to get the motors aligned. I am certain that these new mounts will definitely do the job. If anything, they are overkill. It wont win any beauty contest, but its all I could come up that would work in that small space we have.
                          • dasboata
                            • Dec 2010
                            • 3152
                            #2248
                            Thumbs up Vin !!!
                            • fweasel
                              master of some
                              • Jul 2016
                              • 4287
                              #2249
                              Nice work Vinny. Clock those water jackets while the motors are loose. I'm going to install some rear mounts on my new motors over the winter as well and I don't see them being as easy to use as yours.
                              • Miltoggie
                                • Dec 2017
                                • 18
                                #2250
                                I know this is the modding thread, but has anyone had this happen to them? It is very strange to me that my boat would rip in half by catching air and landing back down causing it to rip at the seam.
