Yes I can shift the packs back. Right now, they are as far forward as possible. However, it tends to ride best with the weight forward. I have a set of ABC 1814's that I have ran before. They gave me an additional 5 mph or so. I want to try them out again on my next run.
I ran the same 3blade props on the Poseidon setup. They didn’t gain any speed over Dasboatas 2 blade 1815s. Not only that but they liked to carry the front end more. You should get easier tuning with the two blade as well as less strain.Comment
Thanks Chris. Looking forward to comparing a set of your props to mine. That short first test showed a couple mph increase with yours We'll see what happens with more testing. Unfortunately, it seems we would have better luck finding plutonium than abc props!!Comment
chris makes a hell of a prop stick with his vers self b/sZelos 36 stock 68 mphComment
I did it for 1 set of 1814's Wanted to compare prep work. I doubt I would do that again. Personally, I like to do my own work. That way win or lose, its mine. Besides, its the only way to learn anything. But that's my 2 cents.Last edited by vinnyp; 10-24-2017, 09:52 PM.Comment
Vac-U-Tug Jr (13mph)Comment
Agreed... It’s about learning skills, making your boat faster thru your own thoughts and actions. I’m with you Vinny!Comment
90mph Zelos
I triple agree! Chris is the best in the business in my opinion and without him I would have never got my best speed to date (90mph or 89.7mph whichever GPS one wants to go by) this afternoon in-between the rain showers! Thank You again Chris for the umpteenth time! It had to be the shirt this time!
102417 Zelos 90mph.JPG 102417 zelos2..JPG Zelos 90mph 10-24-17..JPGTFL Zonda (124mph), Miss Geico Zelos 36 (108mph), Veles 29 (91mph), Zelos Twin 36 (90mph), Miss Geico 29v3 (83.5mph), Sonicwake 36 V2 (83mph), Blackjack 42 (81mph), TFL Pursuit (79mph), UL-19 (75mph), Sonicwake 36 (73mph), Motley Crew (47.5mph), AquaCraft Rescue 17Comment
Finally i had some free time and proceed with replacing the stock motor mounts with some CF that i made.First of all i want to say a big thank you to Michael or as known in the forum as lt130th for his time and the trouble making the templates and then send the drawings to me via email.After the cutting and small adjustments to make em fit in my zelos i glue them in place with chopped CF and resin.Also i ended up removing half of the plastic mounts that are glued on the boat(only reason was because i didn't like the look of them together with the new mounts) and filled the gap with some CF. The finished Mounts are rock solid now and in my opinion the inside of the boat looks a lot better now.Also replaced the stock collets with some new ones from aeromarine (had them on my last run and i have to say they are a huge improvment) new 4mm cooling lines and few other thinks here and there.Some photos
The first look with just the mounts in place.
With the gap from the old motor mount filled.
With the motors installed.
20171212_104413_HDR.jpg20171212_104702.jpgGenesis 36", Zelos Twin 36"Comment
Some more photos with everything installed.
20171212_155515.jpg 20171212_155526.jpg 20171212_155552_HDR.jpgGenesis 36", Zelos Twin 36"Comment
Nice work. Those new mounts should add some rigidity to the sides of the hatch opening as well.
The only other thing I'd change would be to put some 90* nipples on the motor cooling cans so that you can orient the top outlet as close to 12 o'clock as possible. The one on your right motor isn't that far off, but your left motor outlet is really low. The more water you can keep filled into the jackets, the better.Vac-U-Tug Jr (13mph)Comment
