Baller, since this is a 36" thread, I assume that's the size boat you have. Putting 20KW into a boat that size just sounds way over the top! I doubt you could have enough prop on there to even get it to bite. That's 333A at 8s on EACH motor! Surely you got a typo going on there...
Greetings to all!Received my boat like a week ago and had it's maiden run,impressed with the stock speed which was at 54mph after reading all the 70 pages here i see that the best mod to do is changing props(i want to stay with stock electronics for now).Now my question is,how do i come in contact with the member dasboata to order some props also is there any another person who i can contact for making me props?I have no idea on props so it must be some one that i can trust he will do the job correct.This is my first and im trying to learn as much as i can from this place.Thank you allTFL Zonda (124mph), Miss Geico Zelos 36 (108mph), Veles 29 (91mph), Zelos Twin 36 (90mph), Miss Geico 29v3 (83.5mph), Sonicwake 36 V2 (83mph), Blackjack 42 (81mph), TFL Pursuit (79mph), UL-19 (75mph), Sonicwake 36 (73mph), Motley Crew (47.5mph), AquaCraft Rescue 17Comment
Hold on to your ass, because it will fly!!!!' Very impressive RTR with little changes. Problem is ..."it will fly" .... yep grow wings and flip at around low 60's. That's when the trimming comes in... ( adjusting drives and center of gravity, with battery placement.) Have a great time with it...it's a head turner for sure!Zelos 36 stock 68 mphComment
You can reach Dasboata from this site with a PM and he can let you know what he has that would work for you. I have a couple of good props that TRUCKPULL has done and he is on this site as well. The OSE store front sells prepped props from time to time when available or check the "Swap shop" section and you might find some there already prepped or the "Prop talk" section on here and I'm sure you can find more vendor options.Hi jim . This boat is impressive as a RTR. You can get mid to upper 60's maybe 70, with keeping stock electronics, and doing a couple small changes. I have Dabosta X447 props, OSE flex shafts, ( I tried Jeffs wire drives, but did not like the water issue, but some have fixed that issue and they are great drives). I run 6s each. SHARPED RUDDER, and use 220 grit wet/dry sand paper on what touches the water.
Hold on to your ass, because it will fly!!!!' Very impressive RTR with little changes. Problem is ..."it will fly" .... yep grow wings and flip at around low 60's. That's when the trimming comes in... ( adjusting drives and center of gravity, with battery placement.) Have a great time with it...it's a head turner for sure!Comment
Greetings to all!Received my boat like a week ago and had it's maiden run,impressed with the stock speed which was at 54mph after reading all the 70 pages here i see that the best mod to do is changing props(i want to stay with stock electronics for now).Now my question is,how do i come in contact with the member dasboata to order some props also is there any another person who i can contact for making me props?I have no idea on props so it must be some one that i can trust he will do the job correct.This is my first and im trying to learn as much as i can from this place.Thank you allVac-U-Tug Jr (13mph)Comment
Baller, since this is a 36" thread, I assume that's the size boat you have. Putting 20KW into a boat that size just sounds way over the top! I doubt you could have enough prop on there to even get it to bite. That's 333A at 8s on EACH motor! Surely you got a typo going on there...Comment
Well that makes you the Speed Demon of the month! Since you got props, need to get that amperage coupled troughout the system. My calculations show you'll need 8AWG, high strand wire no more that 5" in total length, each side. After that, it goes to 6AWG and you can get to about 8.5" of wire. If you used small wire, you'll just not couple the battery power to the ESC. The amperage level is your biggest challenge. Obviously need to use the largest, highest quality connectors you can get (Castle Connectors). You'll also need close to 1Farad of capacitance external to the ESC on EACH side. At this amperage, the wires have enough meaningful inductance to cause significant voltage surges at the ESC. They won't survive without a huge external cap board. They don't sell these, you have to make them. If you want help there, I will supply part numbers you can use to build this cap board. Maybe we can keep this speed demon from going Chernobyl on you! I hope you got a long lake to get this thing opened up on!Comment
Ok so AGAIN... NOT "16s".. 16 cells yes.. The s in "16s" is for series. 16s voltage is pushing close to 60v "TOTAL". 8s2p is what you have = 2 8s systems in parallel. Apologies but this "Im running a total of 12s or 16s in my Zelos bugs me.Comment
Originally posted by kfxguySmhComment
Originally posted by paulfromtulsahis post are very entertaining say the least. worlds longest boat build hahah. what do you expect from a guy who thinks his zelos is going to be running on 16s lmao
Sent from my SAMSUNG-SM-G928A using TapatalkComment
Second clean up here fellas.
Please knock it off with the bashing. These are after all "toy boats".
The "ignore" feature on the forum works well if someone is getting under your skin.MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
