  • Team Lucas
    • May 2016
    • 300
    #1321
    Originally posted by paulfromtulsa
    I got them installed and bench tested them. They are pretty smooth. I should get her in the water this weekend
    just ordered a set from Jeff this morning. Anything I should know, post it please
    Zelos 36 stock 68 mph
    • REDLINE1
      • Jul 2016
      • 199
      #1322
      I want to hear how these work out as well. I have one on my Spartin and I did have water coming in the tube but I don't think that will be an issue with the zelos because the strut is sealed to the hull over the tube
      • paulfromtulsa
        • Nov 2013
        • 211
        #1323
        You have to cut them to length and also knotch out the stub shaft where the set screw for the dog drive sits
        • Team Lucas
          • May 2016
          • 300
          #1324
          from pics: I saw have to notch it for drive dog. There too long?
          even if you pull drive dog up , or maybe a bigger dog?
          • paulfromtulsa
            • Nov 2013
            • 211
            #1325
            Jeff sends them a couple inches longer so you definitely have to cut them
            • Erroneous
              • Apr 2016
              • 451
              #1326
              I read on another forum that a certain someone is building their Zelos twin aiming to hit 130mph.. Want to chime in "certain someone"?....
              • Team Lucas
                • May 2016
                • 300
                #1327
                • Team Lucas
                  • May 2016
                  • 300
                  #1328
                  What a goal we can all shoot for.....130 mph... shucks, love to hit 70 mph.
                    Well I retract my statement because I thought it was baller69 being referred to
                    • Team Lucas
                      • May 2016
                      • 300
                      #1330
                      Originally posted by kfxguy
                      Well I don't think it will do it
                      See what I did there.....lol
                      Very good! lol
                      • Mxkid261
                        • Jun 2015
                        • 734
                        #1331
                        But thats what the "speed calculator" said it would do, so it must be true!!
                        • Team Lucas
                          • May 2016
                          • 300
                          #1332
                          ok I just got my 6 cell 22.2 volt batteries in, just to double check, I can do away with harness and plug 1 6cell into each esc directly?
                          • paulfromtulsa
                            • Nov 2013
                            • 211
                            #1333
                            That is correct
                            • Team Lucas
                              • May 2016
                              • 300
                              #1334
                              Thanks Paul
                              • TRUCKPULL
                                • 2969
                                #1335
                                What I would do is;
                                Connect the + wires of each ESC together just behind the plugs. so you still have two + plugs from your ESC's.
                                Then connect the two - wires of each ESC together the same way, BUT using a plug in-between.
                                The reason for the plug in-between is for when you are programming your ESC's you can disconnect them from each other.
                                With them connected together your programing may not work.
                                When you connect them this way, each ESC will see a 2S2P setup, therefore you batteries will always pull down the same.
                                If you have one battery connected to each ESC; so you are out running as if on a big oval coarse turning right most of the time,
                                After a few laps of the outside motor being loaded more then the inside motor, when you try to go straight your boat pushes to the left because the right hand battery has more power left in it then the left hand battery.
                                Larry
