  • IRON-PAWW
    • Oct 2011
    • 314
    #1306
    All I'm doing is thinking on the packed air thing and keeping the boat down. Could you vent it somehow with a tube / space (etc etc) through the hull? That might bleed off excess air at speed. Or dare I say it.... some type of airfoil designed to exert a little downforce only at speed.
    PERTH AUSTRALIA
    • Erroneous
      • Apr 2016
      • 451
      #1307
      Airdam. Its in this thread too.
      • daHammer
        • Apr 2016
        • 23
        #1308
        Originally posted by Team Lucas
        my thinking was, with going to just 2x6s I lose weight. 4x 3s weighs 51.6 oz, and 2x 6s weighs 42.8 oz and I will have shorter wires, since I'm not using the harness . longer the wires the hotter they get and loose power. just my thinking on it.
        What brand 6s are they that weight just 42.8oz?
        • Team Lucas
          • May 2016
          • 300
          #1309
          SMC. so far there a bang for the buck. Hard cased, and you can pick your connections. Each 6s weights 21.4 according to there specs.
          Zelos 36 stock 68 mph
          • Team Lucas
            • May 2016
            • 300
            #1310
            • Team Lucas
              • May 2016
              • 300
              #1311
              with props spinning out, it sure throws a tail that doesn't land till your over 20 feet past it, doing 65 mph.DSC_0069.jpg
              • Team Lucas
                • May 2016
                • 300
                #1312
                • gman350
                  • Aug 2015
                  • 31
                  #1313
                  Originally posted by Erroneous
                  Its in this thread. Id say about 9-10 pages back.
                  Looks like on page 25.
                  • Team Lucas
                    • May 2016
                    • 300
                    #1314
                    what are you asking about GMAN?
                    • gman350
                      • Aug 2015
                      • 31
                      #1315
                      I noticed grease oozing between my struts & the transom. Also the mounting bolts always need a 1/2 turn or so after running, which tells me they are pulling thru. I intend to add some plates like Erroneous did, but until then I added some support blocks between the strut mount and the transom overhang. Hopefully will help alleviate some of the stress.
                      • Team Lucas
                        • May 2016
                        • 300
                        #1316
                        trying it again :)
                        • Team Lucas
                          • May 2016
                          • 300
                          #1317
                          I get the "
                          oozing grease" thing also, but every other run I snog things down, and hasn't been a problem. I even ran up on a back end of a boat that just died in front of me, went air-born twice at over 60, and still hull is crackles. don't over tighten, just snog it and do it offen.
                          • REDLINE1
                            • Jul 2016
                            • 199
                            #1318
                            Mine oozes as well took the struts off last night cleaned everything up reassembled with some silicon sealer to seal the screws and strut up. I was surprised how thin the hull was at those strut mounting points. I could see beefing them up some with fiberglass or metal plate
                            • Team Lucas
                              • May 2016
                              • 300
                              #1319
                              Originally posted by paulfromtulsa
                              Pics of the wire drives
                              Sent from my SAMSUNG-SM-G928A using Tapatalk
                              Have you tried the wire drives yet?
                              • paulfromtulsa
                                • Nov 2013
                                • 211
                                #1320
                                I got them installed and bench tested them. They are pretty smooth. I should get her in the water this weekend
