  • Team Lucas
    • May 2016
    • 300
    #1261
    Originally posted by paulfromtulsa
    I am going to use the same liner. Hopefully water doesn't get into the hull. We will find out soon
    From what I know of these "wire drive" you cant just run them in the brass drive tube. They have a bearing dive tube for those, has 4 ball bearings in it. There's no way in my mind that w/o those bearings it wont rub, and when it does rub, it's so thin it will either eat a hole in the tube, or shaft get too thin and break. Zelos has that bend at engine side, how will you stop it from rubbing the top part of the brass tubing at that bend? Granted I don't know much about these other then a guy at my pond is running "wire drive" in a gasser.
    Zelos 36 stock 68 mph
    • Team Lucas
      • May 2016
      • 300
      #1262
      I bought the OSE upgraded flex shafts and here is what I like to point out. There barley longer and why you can fit a bigger prop is because they have a tiny drive dog. the steal shaft is shorter and that's better, but definitely change the drive dog.saft dirrerence.jpgshaft 2.jpgdrive dogs.jpg
      • REDLINE1
        • Jul 2016
        • 199
        #1263
        The wire drive from wohlts is a drop in replacement for the cable. No bearings , just need to change out the collet on the motor. Leave the existing liner in. I put one in my spartin , much smoother than the cable but I did have some water leak when sitting in the bathtub because the wire is smaller than the cable. Ended up making some seals out of cooling tube in each end of the brass tube
        • Team Lucas
          • May 2016
          • 300
          #1264
          I went to that site and it says "coming soon"...and where can I get the collets for them?
          • REDLINE1
            • Jul 2016
            • 199
            #1265
            [QUOTE=Team Lucas;673640]I went to that site and it says "coming soon"...and where can I get the collets for them?[/QUOTE
            Ya I think he's testing them The one I bought for the spartin came w the collet so I assume he will provide the collets with it
            • paulfromtulsa
              • Nov 2013
              • 211
              #1266
              Got the wires drives installed today and they seem pretty smooth. Will get her in the water this week. Also Jeff sells the collet for them just email him
              • REDLINE1
                • Jul 2016
                • 199
                #1267
                image.jpgimage.jpgimage.jpgimage.jpgWhat do you guys think of this idea to scoop more water into the inlets on the bottom of the hull? They are push rod exit covers I had lying around from my rc plane days. Epoxy them over the stock inlet tubes. Not sure if they would stay on or get ripped off. Or create too much drag
                • baller69
                  • Aug 2016
                  • 45
                  #1268
                  so i decided to do so,ething different so i decided to get the zelos hydro dipped in gold carbon fiber with several coats of clear.it actually turned out really well.plus my properlly sized water jackets are finally done so now the fun begins as it is now time to engineer my build.thanks for looking!
                  • TRUCKPULL
                    • 2969
                    #1269
                    [ATTACH=CONFIG]146649[/ATTACH][ATTACH=CONFIG]146650[/ATTACH][ATTACH=CONFIG]146649[/ATTACH][ATTACH=CONFIG]146650[/ATTACH]What do you guys think of this idea to scoop more water into the inlets on the bottom of the hull? They are push rod exit covers I had lying around from my rc plane days. Epoxy them over the stock inlet tubes. Not sure if they would stay on or get ripped off. Or create too much drag
                    Don't do it.
                    The picture below shows all that is needed.
                    Your's should be sanded flat to reduce the drag.
                    Larry
                    • ray schrauwen
                      • 9472
                      #1270
                      Originally posted by truckpull
                      don't do it.
                      Larry
                      ditto !
                      Nortavlag Bulc
                      • ray schrauwen
                        • 9472
                        #1271
                        So I'm Informed by "Rawsteele" via YouTube that I would have too go through him to get a motor from Jose. Is this correct? Nice motors.
                        Nortavlag Bulc
                        • REDLINE1
                          • Jul 2016
                          • 199
                          #1272
                          Originally posted by TRUCKPULL
                          Don't do it.
                          Larry
                          Ok thanks
                          • Keagan-Z06
                            • Mar 2016
                            • 970
                            #1273
                            Wow!
                            • fweasel
                              master of some
                              • Jul 2016
                              • 4288
                              #1274
                              The dip looks pretty sweet. Should gone with the C-note pattern.
                              Vac-U-Tug Jr (13mph)
                                No! Leave it stock or shape it like truckpull showed you. Btw, I shaved mine at and did them like that it it didn't pick up anything. At all. (Mph wise). In other words it didn't go any faster.
