  • prepered
    • Jan 2018
    • 59
    #2311
    Thanks I will do that :-)
    • Sachaken
      • Oct 2015
      • 10
      #2312
      Hi guys,
      I'm preparing mine for the summer but had an accident with the zelos last year that I'm fixing at the moment.
      My boat submarined and hit some rocks at the bottom of the lake though it was pretty deep. 3-4 meters. I am repairing the crack with epoxy but the paint is screwed up at the front of the boat.
      I'm thinking about a complete new paintjob.
      What do you think, sand the old paint from the boat completely and use carpaint? or what is the best way to do it?
      Thanks in advance, I've been trough the thread the past year and really learned a lot of you guys!
      Happy boating to you all.
      • prepered
        • Jan 2018
        • 59
        #2313
        Hi Guys.
        Just got my zelos OSE flex cable today. But I wonder if the lable on the cable is wrong. The red label says right side I think its wrong ???
        • MADRCER
          • Feb 2017
          • 751
          #2314
          The cable with the "R" on it needs to be installed in your left side strut (since that motor should be rotating to the right when you run it) and put the other one in your right side strut. The "R" doesn't mean it's for the right side, it means it's a "right rotation" flex.
          • prepered
            • Jan 2018
            • 59
            #2315
            Thanks Madrcer I was also confused about that label .
            • Miltoggie
              • Dec 2017
              • 18
              #2316
              The "R" is right rotation but on the Zelos it still goes on the Right Side since that motor spins to the right, you will unwind that cable if installed on the left side.
              • prepered
                • Jan 2018
                • 59
                #2317
                Now im totally confused.
                • Team Lucas
                  • May 2016
                  • 300
                  #2318
                  you running props in or out?
                  Zelos 36 stock 68 mph
                  • prepered
                    • Jan 2018
                    • 59
                    #2319
                    Props are running stock in.
                    • vinnyp
                      • Mar 2017
                      • 283
                      #2320
                      A simple way to get this right is to look at the wind in the flex. As the motor turns the flex, the wind should tighten as it spins the prop.
                      • martin
                        • 2887
                        #2321
                        If the props are turning inwards then the flex with the R on it goes to the left or port side of the boat, this will not unwind the flex but tighten the wind.
                        • fweasel
                          master of some
                          • Jul 2016
                          • 4285
                          #2322
                          This is not correct. In stock form, the props on the Zelos spin inwards. That puts the the cable marked with an R on the left/port side of the hull.
                          [ATTACH=CONFIG]158821[/ATTACH]
                          This photo is worded properly, but the position the cables are laid on the table next to one another is misleading. They should not be install in your Zelos as pictured here. As previously stated, the cable marked with an R gets installed on the left/port side of your hull. When both installed, the winds of both flex cables will make a ^ pattern, pointing towards the bow.
                          Vac-U-Tug Jr (13mph)
                          • prepered
                            • Jan 2018
                            • 59
                            #2323
                            Thanks guys. I got it now appreciate your help.
                            • prepered
                              • Jan 2018
                              • 59
                              #2324
                              Hi Guys
                              Just finish putting the zelos together again and align the flex shaft. My question is if it will be and advantage if I change the motor timing , im running 45 mm cnc props.
                              And what will be good.
                              • fweasel
                                master of some
                                • Jul 2016
                                • 4285
                                #2325
                                ESC timing should be set at 7.5* for the stock 2000kV motors, either version.
