  • REDLINE1
    • Jul 2016
    • 199
    #1591
    Got my Wohlt wire drive kit yesterday. Very nice bullets lock nuts drive dogs and collets included. Just tested it in the bathtub no leaks.
    • fweasel
      master of some
      • Jul 2016
      • 4286
      #1592
      Did you have to cut them down at all? I took about 4mm off and there's still plenty of wire in the collet, but I can now position the drive dog any distance from the strut. Maybe that's what 'll do today, flat the boat in the bathtub where its warm
      Vac-U-Tug Jr (13mph)
      • REDLINE1
        • Jul 2016
        • 199
        #1593
        [QUOTE=fweasel;677906]Did you have to cut them down at all? I took about 4mm off and there's still plenty of wire in the collet, but I can now position the drive dog any distance from the strut. Maybe that's what 'll do today, flat the boat in the bathtub where its warm [/QUOTE
        No cutting. Moved the motors all the way up toward the bow then had to move them back towards the stern to get the wires to bottom in the collet and leave a few mm spacing between drive dog and strut. I used the stock drive dogs because they were slightly larger dia and a little longer
        • Mxkid261
          • Jun 2015
          • 734
          #1594
          Originally posted by kfxguy
          So I had a little free time tonight. Finally installed the new motors. If I can I'll go run it this weekend and see if I can better my 76mph best.
          Can't really even see them
          Bout time you get that thing finished
          • REDLINE1
            • Jul 2016
            • 199
            #1595
            Happy thanksgiving guys!
            • Team Lucas
              • May 2016
              • 300
              #1596
              same to you Redline...hope yours was great.
              Zelos 36 stock 68 mph
              • REDLINE1
                • Jul 2016
                • 199
                #1597
                Was great I ate too much LOL. Supposed be 50 on Sunday up here gonna get the Zelos out for a few runs and test the wire drives
                • Mini40man
                  • Aug 2016
                  • 4
                  #1598
                  Hey guys, has anyone thought of a duel water pickup rudder, or did I miss it in another post? I'm just concerned of stock water pickups not always being in the water all the time.
                  Hello yes I have. Ever since getting the Zelos earlier this year I have been worried about the water cooling. I have read all the discussions from Rafael stating that the water should not flow too fast, but quite often I could not see any water coming out at all. Here in Manila we have hot dirty water conditions so have been very concerned about this.
                  The first test was to use a Genesis cat twin pickup rudder from OSE. The stock is a bit thin so I packed it with washers both sides. It is also a bit shorter than the standard rudder so cornering saw quite a bit of skidding. With this rudder I jumped up to 113KPH (sounds more impressive than 70.7MPH), and can be seen in use in this video link below. For this test I merely connected the two under-hull pickups with a plastic tube in case I wanted to revert back to the standard setup. However the test went really well and I have now sanded off and filled up the hull pickups - I am staying with the twin pickups in the rudder.
                  I have now got a larger rudder from rcboatbitz. It comes 165mm deep and I have cut 15mm off the bottom. This only needs one washer to pack it in the Zelos rudder fitting. I am trying this rudder out tomorrow
                  3 rudders to compare.jpgZelos 36 twin p-up all.jpgZelos 36 twin p-up closeup.jpg
                  Some photos showing the three rudders, and the new one fitted are attached here
                  Zelos 36, Mean Machine, Pursuit
                  • Yellow
                    • Jan 2016
                    • 81
                    #1599
                    Wow! What a cool modification! Looks factory. I was also wondering about this. I'm diggi'n the pain job too! Let us know how it goes.
                    • Team Lucas
                      • May 2016
                      • 300
                      #1600
                      [ATTACH=CONFIG]147926[/ATTACH][ATTACH=CONFIG]147927[/ATTACH][ATTACH=CONFIG]147928[/ATTACH]
                      Thanks for sharing this MiniMan keep me informed of that last one from rcboatbitz. What link for it etc... BTW, very nice boat.
                      • Keagan-Z06
                        • Mar 2016
                        • 970
                        #1601
                        I had offshore withdrawal, anyone else?
                        • Revolt Flash
                          • Aug 2015
                          • 437
                          #1602
                          Me too.
                          • Team Lucas
                            • May 2016
                            • 300
                            #1603
                            I just ran a set of Dasboata X447's last sunday. When opened the package, I was impressed that they came with a couple stickers (love product stickers). I checked one out one my balancer ...perfect... then noticed there engraving on the hub, wow nice ! Also looks like he cut the tounge a little. Now the important part, getting them wet. Knowing these are sharp as a knife, taking off slower is a must, or it will just cavitate until they catch water. Was hard to judge just how much speed was gained since I readjusted my settings from when I ran it a week ago, but can tell it did gain speed. Very nice props, was here when promised. If you are running 447's, should give these a try. Great job Chris.
                            • fweasel
                              master of some
                              • Jul 2016
                              • 4286
                              #1604
                              My Dasboata 447's cavitate much less and hook faster than my stock props ever did. Can't wait to get them back.
                              • Mini40man
                                • Aug 2016
                                • 4
                                #1605
                                The new rudder works well. you asked for a link to the rudder. It is here: www.rcboatbitz.com.au
                                http://www.rcboatbitz.com/index.php?...yword=502B52-a
                                (reference 502B52-A)
                                I chose it simply because it had twin pickup, was long enough, and had the right head of the rudder to fit the Zelos stock. I had to move the hole for the sacrificial crash bolt up slightly and it is also a fraction too narrow, and I solved this with washers for Sunday, but that is not a good solution - there was some vibration - and have now painted the head of the rudder with a mixture of west epoxy and finely chopped carbon and after filing off 90% of the coating I now have a nice snug fit and will test again today.
