  • Team Lucas
    • May 2016
    • 300
    #1636
    Originally posted by dasboata
    3/16 shaft ? 10/32 .thread 187 ,,3/16" diameter
    The prop man!
    Zelos 36 stock 68 mph
    • dasboata
      • Dec 2010
      • 3152
      #1637
      Originally posted by banixj
      can you please write a link for the nyloc nut? colored if possible...
      http://www.offshoreelectrics.com/pro...?prod=ose-8135 these nuts work just a as good as the nylocks
      • ray schrauwen
        • 9471
        #1638
        Even better. I lost a very nice 455 you did for me on first run with nylock nut.
        Nortavlag Bulc
          stock electronics, 2x 3S in series
          i'm sure that props are too large for summer running...
          for this winter i hope they will be ok!
          if the props are good in quality i will purchase a medium size for the summer... 43, 44 or 45mm
          Those props are not aggressive props plus aluminum flexes so it loses pitch. I'd be surprised if they went faster than stock sharpened props. I feel like kinda you took a step backwards. The only positive is it seems like 47mm diameter is liked by the boat. Don't hurt to try something different than everyone else tho. Interested in seeing the results.
            I've never lost a prop using deez nuts.
            Lmao.
            • Keagan-Z06
              • Mar 2016
              • 970
              #1641
              Lmao.
              • banixj
                • May 2012
                • 107
                #1642
                dec 18th test report
                today i went to the lake to test my stock Zelos with nu props!
                below all the details!
                weather:
                air temperature: 50F 10C
                water temperature: 39F 4C
                wind: 7.5mph 12kmh
                waves: small but persistent
                Boat:
                electronic: stock
                ESC timing: 7.5
                shafts: polished
                lubricant: quicksilver 2-4-C and Pakelo 5W30 full synth motor oil
                struts: leveled as out of the box
                props: TFL CNC 4714 alu
                lipo: 2x 3S Turnigy Nanotech 5A 65-120C NOT fresh
                Results:
                balance: perfect, no flip trend
                Top speed: 63mph 101kmh (instead of 55mph 88kmh with stock props)
                Battery time: 3'30" (instead of 4min with stock props)
                Left temps: ESC 90F 32C motor 108F 42C
                Right temps: ESC 86F 30C motor 95F 35C
                Problems:
                during dock return, right motor power go down, then blinking red light on right ESC...
                temp of one of the battery plug went up coz some fused plastic around it...
                stock servo is really slow... ok for normal running... not so much for emergency turn...
                Conclusion:
                My dream come true and this make me happy...
                I know i should sharpen the props but i'm not able to do it...
                I know low lake temp helps electronics, so i need a medium prop for summer to preserve electronics... but i'm happy of TFL!
                Please help me to solve the ESC red blinking problem... maybe LVC threadsold is different in the right ESC? crazy...
                HPR 115 kevlar bulletproof @90mph, MHZ Rapid carbonfiber, Bingo Race Minieco
                Futaba AIR TX/RX system with telemetry
                • Team Lucas
                  • May 2016
                  • 300
                  #1643
                  Great to hear Banixj. great report, and glad to see your in the 60's
                    • 9488
                    #1644
                    Awesome!
                    • Erroneous
                      • Apr 2016
                      • 451
                      #1645
                      New props on the way. Few other things being toyed with as well. More info as this madness unfolds.
                      • banixj
                        • May 2012
                        • 107
                        #1646
                        no one can help me about red blinking led on one of the two esc?
                        • REDLINE1
                          • Jul 2016
                          • 199
                          #1647
                          Same thing just happened to me . Left side ESC. start out green after a pass or two reduced power on that side and red flashing . Called Horizon tech said its the low voltage cut off indication, only I didn't have low voltage and both esc's were set at 3.2v. He ended up sending me a new esc. I put it in but haven't had a chance to try it because the lakes around here are now ice. Check the low voltage setting on the esc that's flashing verify its not set on one of the higher settings ,if not contact Horizon
                          • banixj
                            • May 2012
                            • 107
                            #1648
                            how to check without program card? if i enter in program mode with transmitter i can not check the selected value: i can only select the desired value without know the previous one...
                            • REDLINE1
                              • Jul 2016
                              • 199
                              #1649
                              It can be done but ive never done it. Sounds like a PITA to do that way . Just buy a card not very expensive
                              • Keagan-Z06
                                • Mar 2016
                                • 970
                                #1650
                                You didn't change the chemistry on the ESC by chance right? The little black button?
