Three NAMBA FE SAW Records set Today
  • BILL OXIDEAN
    Banned
    • Sep 2008
    • 1494
    #46
    King Of Shaves Saws Pass
    Heres my king of shaves project making a pass.
    I changed to bigger rotors and speeds went down but so did temps DRASTICLY.
    I can totally prop up and advance timing..
    • RaceMechaniX
      • Sep 2007
      • 2833
      #47
      Originally posted by Fluid
      Yep, you learned it the hard way, just like Brian did and then me. Kept the Q Offshore record solid for years, and a few others too. Very frustrating, but glad you made the requisite passes.
      Yup, I have learned. Funny thing is at the 2-lap event, both work flawlessy with the same motor, but older lipos. I updated to a set of 45C Hyperions and no luck.
      More testing is necessary.......
      Tyler
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • Doug Smock
        Moderator
        • 5272
        #48
        Originally posted by Chris Harris
        Jay,
        What version programming did your Schulze have? We have experienced the same thing your saying with v14 and below on D winds but v16 has been flawless IME.
        Chris
        It must be geographical.
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
        • ReddyWatts
          • 1711
          #49
          Changing to a 45C bat made the problem appear. This would increase the amps with a better voltage source. How many amps is it using? IMO, that does not sound like a feedback pulse problem. I would try removing the connectors between the motor and esc, then replace them with shorter larger wires and add caps to the source.
          Something may be heating up, if it happens on the second run.
          ReddyWatts fleet photo
          • Chris Harris
            • Oct 2007
            • 182
            #50
            Not saying it was a user problem Jay and I agree it wasn't just a coincidence just trying to see what, if any, differences there were between what you guys were using and what we've been using, that's all.
            Chris
            I.M.P.B.A. Record Holder P-Hydro 111.001mph Q-Hydro 120.192mph S-Hydro 139.233mph
              #51
              No problem Chris, I was just making sure everyone knew how widespread the problem was as I'm also getting PMs about it. I'm not surprised that the problem isn't bad when running 2-lap events, the amp draw is a lot less than with SAW use. I tested the original pairing on a small local pond and it worked well - just not at full-draw on Legg Lake.
