Zippkits jae 21fe v2 outrigger_wood kit build
  • sammyha
    • Jul 2018
    • 1038
    #76
    I get the inside of the tub and the bottom ski sealed...
    Sent from my SM-G950U1 using Tapatalk
    • sammyha
      • Jul 2018
      • 1038
      #77
      I bought a 12" x 48" sheet of 1/16" birch plywood from Balsa USA.
      And got all the pieces cut for making a scratch built stealth cowling...
      • sammyha
        • Jul 2018
        • 1038
        #78
        Here's the dimensions for anyone who's interested...
        • sammyha
          • Jul 2018
          • 1038
          #79
          Here's the stealth cowling mocked up...
          • sammyha
            • Jul 2018
            • 1038
            #80
            Second coat of sealer on the inside of the tub, and epoxied in an ESC tray...
            • sammyha
              • Jul 2018
              • 1038
              #81
              I know you guys know about my YouTube build series, and I'm not doing this to get views. There's just so much more info passed along in the video format.
              Here's a link to Part 11 of the series, the stealth cowling layout and dimensions are in the second half of the video...
              • sammyha
                • Jul 2018
                • 1038
                #82
                The scratch built stealth cowling is coming together...
                • sammyha
                  • Jul 2018
                  • 1038
                  #83
                  It's surprisingly light. Still want to at least fiberglass the outside corners. I think it's worth the extra weight for looks alone...
                  • sammyha
                    • Jul 2018
                    • 1038
                    #84
                    There's a lot more room under there...
                    • sammyha
                      • Jul 2018
                      • 1038
                      #85
                      I can't wait till tomorrow.
                      It's always good to be over this scramble...
                      • sammyha
                        • Jul 2018
                        • 1038
                        #86
                        Here's a detail I forgot to show about changing to a one piece cowling. I removed the center web from the top deck, made two 25-1/2" lips, and routed two notches to clear the lips...
                        • sammyha
                          • Jul 2018
                          • 1038
                          #87
                          I used 2 ounce fiberglass to reinforce the stealth cowling. I have all butt joints, no interlocking tabs...
                          • sammyha
                            • Jul 2018
                            • 1038
                            #88
                            Make sure you build a left and a right sponson!
                            I now have all the sheeting on the sponsons.
                            • sammyha
                              • Jul 2018
                              • 1038
                              #89
                              I'm leaving the extra width on the ride pads hanging on the outside of the sponsons. I tapered the non-trip pads up to the nose blocks.
                              Experience tells me the extra area will help carry the heavier 6s setup.
                              • sammyha
                                • Jul 2018
                                • 1038
                                #90
                                Want a nice uniform radius? Sand two 45 degree angles, keeping them uniform. Blend the radius to those surfaces, checking the shadow of the radius often...
