Zippkits jae 21fe v2 outrigger_wood kit build
  • sammyha
    • Jul 2018
    • 1038
    #121
    My stealth cowling attaches with magnets. No tape! Hooray!
    The front is locked down with a tab. The round metal buttons are held down with the magnets and can't slide back because they're backed up with a former.
    Sent from my SM-G950U1 using Tapatalk
    • sammyha
      • Jul 2018
      • 1038
      #122
      To remove, pull the clear tab up to release the magnets and slide the cowling backwards.
      It's a clean looking setup...
      • sammyha
        • Jul 2018
        • 1038
        #123
        Here's a link to a video on my stealth cowling attaching with magnets...
        • sammyha
          • Jul 2018
          • 1038
          #124
          I have some pictures to share. I've installed the rest of the electronic components and hardware that make it go.
          These final details of a build takes hours, but is very enjoyable to me...
          • sammyha
            • Jul 2018
            • 1038
            #125
            The transmitter is programmed, and I've bound the receiver with a 4.8 volt pack.
            And plugged in the lipos and taught the throttle end points. Without a smoke show!
            I've also set the motor timing, LVC, and motor start power with the ZTW programming card. The motor direction was right on the first try...
            • sammyha
              • Jul 2018
              • 1038
              #126
              I'm 0.7 ounces over the high end of the recommended weight range of 5 to 7-1/2 pounds. Not bad considering the electronic components I have in there. It should pull that weight fine if it floats...
              • sammyha
                • Jul 2018
                • 1038
                #127
                The CG is about a 1/2" behind the back of the turn fin right now when I hang it. That's with the slightly lighter You & Me lipos all the way back. The Revolectrix lipos are about 4 ounces heavier, so I can easily move the CG farther back using them.
                I'm not a fan of too far rearward CG settings. I feel like they over steer and hook the turns. I'll have to run it and see. Zippkits riggers really do turn strong. Maybe that's why.
                But very cool stuff, I have my electronic components where they need to be...
                • sammyha
                  • Jul 2018
                  • 1038
                  #128
                  Here's an accurate way to check CG. They recommend 60/40, I'm at 64/36 right now.
                  I have it setting on the back edge of the sponsons on boxes, and the tub sitting level...
                  • sammyha
                    • Jul 2018
                    • 1038
                    #129
                    Me posing with my latest creation...
                    • sammyha
                      • Jul 2018
                      • 1038
                      #130
                      Here's a YouTube link to the last video in this build. Just go watch it, you'll see so much more watching a video...
                      • sammyha
                        • Jul 2018
                        • 1038
                        #131
                        I purchased the Zippkits stand and built that too.
                        Two coats of sealer and two colors on it adds more time to building a stand, but sure adds a nice touch to it...
                        • Joe Petro
                          • Dec 2009
                          • 10
                          #132
                          Very nice! I love every bit of this!
                          BTW: The original name was 33FE. The boat length in the name seemed like a good idea. We had a substantial number of customers ask what happened to the 21FE.
                          So the 33FE is the 21FEV2. Around here, it's the '33...
                          Keep up the great work, and post a vid of your facial expression with the first run...
                          Joe
                          • sammyha
                            • Jul 2018
                            • 1038
                            #133
                            Got the maiden done in the hot pond...
                            • ezhitz
                              • Aug 2009
                              • 428
                              #134
                              Looks good. I like that spot what a way to spend a Saturday a little late season ice fishing and in between bites run my boat. Lol
                              Great to see your build go from start to finish have fun this summer running and tuning.
                              :canada
                              • sammyha
                                • Jul 2018
                                • 1038
                                #135
                                Thank you. Yes, that's a very unique place to test a boat in February.
                                Zippkits designs are so good. I feel that was such a solid run on a bench tune...
