ML Boatworks RSX380 Outrigger! My first FE wood kit build...
  • sammyha
    • Jul 2018
    • 1037
    #406
    Originally posted by vvviivvv
    Any updates on this?
    Just read it fully and contemplating one for some left over 6s equipment... more would be a sport setup with a quick prop change to SAW capabilities... just undecided on this or trying to package in the smaller boat a 6s setup.
    No updates, besides the fact that I love the boat, the design, the handling. No bad characteristics that I can tell. Nice kit to build too.
    I think 6s would be fine if you built it light. I think you would benefit from the longer length. It tracks nice.
    Mine came in at nine pounds all up with 8s lipos in it. Keep it around seven pounds on 6s and you should have a great saw run rigger...
    • vvviivvv
      • May 2009
      • 1079
      #407
      im thinking Lehner maybe 2240/7 or similar around 1900-2000kv
      Or am i going to see flames hmm.
      Uk SAW record holder
      • Troy1957
        • Jun 2022
        • 27
        #408
        Please help. RSX380 outrigger with 4092 1390 kv 2218-10-50 abc prop on 6s can't figure out amps for speed controller. And would this be a good 6 lap setup? Thanks in advance. Oh I'm a rookie.
        • Peter A
          • Sep 2012
          • 1486
          #409
          What batteries are you running?
          I race a sport hydro with a TP 4060 1350k, Panther Graphene 6s 6000 mah, ZTW 200 esc on a ABC 1915 17 45 prop., speeds in the 100+ kph. Different hull type but it's a ballpark. I think you should start smaller on props and work up.
          Either the ZTW 200 esc or one of the Castle offerings, mamba X or XLX2
          • Troy1957
            • Jun 2022
            • 27
            #410
            Haven't even thought about battery brand. And I guess 6000mah. And I'm guessing that 2218 prop would be for saw run?
            • Troy1957
              • Jun 2022
              • 27
              #411
              Peter are you running 1 6s battery or 2 3s?
              • Steven Vaccaro
                • 8720
                #412
                Im with Peter, a ztw 200 will work with that motor. But not that 2218 prop. If you want to push the system hard, Id run a Castle hydra
                https://www.offshoreelectrics.com/pr...as-010-0173-00
                Steven Vaccaro
                • Troy1957
                  • Jun 2022
                  • 27
                  #413
                  Would you suggest a couple of props please.
                  • Peter A
                    • Sep 2012
                    • 1486
                    #414
                    One 6s battery.
                    • Steven Vaccaro
                      • 8720
                      #415
                      Id start with an octura 1450 and move up or down from there with testing.
                      Steven Vaccaro
                      • Troy1957
                        • Jun 2022
                        • 27
                        #416
                        Awesome Thanks Steven
                        • sammyha
                          • Jul 2018
                          • 1037
                          #417
                          Update on my RSX380. I've got it running in the nineties! I'm still learning, lol...
                          Specs on the boat- Motor Leopard 4092 1390kv, Esc ZTW 200 amp on 8s. I just bought a pair of 4s SMC lipos and this was on an ABC 1820-22-45 prop.
                          Remember, if it don't make your knees knock it's not with doing!
                          Here's the video...
                          • Xrayted
                            • Jan 2023
                            • 273
                            #418
                            Very nice speed! And yeah, things start to get a bit sketchy and scary once up near the triple digit mark. That's how you know you're doing it right!
                            • larryrose11
                              • Jun 2010
                              • 757
                              #419
                              The SMC lipos test out well. I have a set for one of my riggers, but have yet to test them.
                              Any idea on what difference just the SMC Lipos made?
                              • sammyha
                                • Jul 2018
                                • 1037
                                #420
                                My previous best was 82mph. With same basic setup it did 91mph yesterday. Today I moved the batteries all the way back and ran an ABC 1820-22-45 prop(was 1819-17-45) for the 93mph run.
