ML Boatworks RSX380 Outrigger! My first FE wood kit build...
  • rol243
    • Apr 2017
    • 1038
    #376
    looks great other than some rear end hop which no doubt you will set correctly with either a different prop and or strut adjustment. what size motor did you end up using ?
    • sammyha
      • Jul 2018
      • 1038
      #377
      I went with the Leopard 4092, 1390KV on 8s. Alright, please tell me about the rear end hop. I didn't even know of that term to describe it. I just prepped this prop and it seems to be closer to waking the boat up, so what strut adjustment helps the rear end hop?
      Sent from my SM-G950U1 using Tapatalk
      • Peter A
        • Sep 2012
        • 1492
        #378
        Bring the strut up to get rid of the hop, small amounts at a time.
        • rol243
          • Apr 2017
          • 1038
          #379
          other causes will include the prop and cog. if the rear of tub is too light it will want to bounce [ hop ] you don,t want a lifting prop on this rigger as there are rear sponsons to keep the back riding well.
          • sammyha
            • Jul 2018
            • 1038
            #380
            Thanks guys. I will be tuning and testing more soon. This is starting to get fun. Also I would appreciate knowing what type prop to order that is not a lifting prop...
            • sammyha
              • Jul 2018
              • 1038
              #381
              Here's a video with some trim changes...
              • sammyha
                • Jul 2018
                • 1038
                #382
                Got out and ran the RSX380 again. Raised the strut a bit more and set some more positive angle to the strut. Now I know I need a prop change.
                I did not like how it turned, it over steered and had some kind of hop going on. Need a higher rake prop...
                So I did a SAW run and broke eighty!
                • rol243
                  • Apr 2017
                  • 1038
                  #383
                  well, you are starting to gain some good speed now , looks great. as your now doing just play with props / strut heights and c.o.g. plus different turn fins certainly help in correcting not so good turns. not sure if you do need to use lifting props on this rigger as you do have 2 x rear sponsons that do hold the rear up at the correct level.
                  • sammyha
                    • Jul 2018
                    • 1038
                    #384
                    I'll try a higher rake prop next. As I said in the video, I've raised the strut bottom 3/32" above the rear shoes. Feels like I've lost some handling with that setting. Batteries were all the way back. From memory, the CG is around 75% of the measurement from the prop to the back of the sponson ride pads...
                    • rol243
                      • Apr 2017
                      • 1038
                      #385
                      so where is the boat balancing when you test the c.o.g. ? should be around the trailing edge of turn fin normally. also can you reduce abit of rudder throw as the model does look like its turning sharp so maybe less throw might correct handling issues aswell. have you tried any octura x or m series props yet ?
                      • sammyha
                        • Jul 2018
                        • 1038
                        #386
                        The c.o.g. is right at the turn fin trailing edge.
                        Hmmn, I setup up three drive modes, each with differing dual rates, 100%, 75% & 50%. Suppose I should try them, huh? Forgot about using them and it wasn't a problem running slower... [emoji57]
                        Please recommend Octura props in the X or M series that compares in size to what I'm running now. It's a ABC 2018-10-50(2)-CLL. And why to use them? They don't list their rake angles, so I didn't buy any.
                        Thank you for all your help...
                        Here it is, balanced on a spare boom tube...
                        • rol243
                          • Apr 2017
                          • 1038
                          #387
                          Paul, [ 758boats ] will know the good cog spot and blade size as he runs a fast ml rigger. as for the octura props, sizes of around x447 / x645 / x646 may be good for oval set up.
                          • sammyha
                            • Jul 2018
                            • 1038
                            #388
                            Thanks. Yeah, those are smaller diameter and pitch props than what I started out with.
                            I've been headed that way with the props I'm trying now.
                            And there's the OSE calculator numbers and there's real world experience. It gave me a starting point anyway, even tho I leaned toward the optimistic side which seems to stress FE electronics...
                            • sammyha
                              • Jul 2018
                              • 1038
                              #389
                              A couple of shots of the RSX380 on the water...
                              • rol243
                                • Apr 2017
                                • 1038
                                #390
                                don,t those octura x series props have less pitch than your 2018 abc ?
