DF pirate 35 build
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    #226
    Then tape everything off ond spread epoxy
    Then peel remaining tape once it's where I want it
    • Fella1340
      • May 2013
      • 1035
      #227
      The cf flat bar looked to me lke epoxy with the motor mount on It looks great though now that you actually have things in there. It has been awhile since i used the wind sheild urethane, i forgot about the mess it can create. It brings back some bad nightmares, its an absolute nightmare if things get out of hand. Thanks for the reminder and I will be rethinking my my plans for using the stuff. It's not worth the hastle and it won't work using a syringe as it's just to thick. I get what your saying about the aquarium sealant, using a flexable bonding agent makes sense for the long stuff like battery trays though. Its a tough call on what to use, I can't make up my mind anyways!
      Last edited by Fella1340; 03-15-2015, 07:53 PM. Reason: poor command of the english language
        Make Total Destroy
        • Mar 2014
        • 1952
        #228
        I just bought the stuff Keith bradley sells. It's designed for saltwater aquariums, so it's gotta be super stuff.
        • flraptor07
          • Aug 2013
          • 2451
          #229
          Did you scuff all the mating surfaces of the CF bar and the mount before you epoxied the mount down? BTW Lookin' great!!
            Make Total Destroy
            • Mar 2014
            • 1952
            #230
            Yeah, with some 60 grit automotive paper.
            It may not be necessary but whatev. Can't hurt rite?
            • flraptor07
              • Aug 2013
              • 2451
              #231
              Good, Glad to hear it! And yes it is necessary if you want it to stick...
                Make Total Destroy
                • Mar 2014
                • 1952
                #232
                Yeah I think it stuck. I picked it up by the motor and shook the whole boat and it's solid mehehe
                  Make Total Destroy
                  • Mar 2014
                  • 1952
                  #233
                  I mounted the hardware for water. All bolted up and ready. Still gotta do the prop.
                  I hope I did the stinger rite. I just have the stuffing tube come out of the transom like 1/8 inch. It doesn't go into the stinger it'self.
                  • nata2run
                    customcfparts.com
                    • Nov 2011
                    • 1837
                    #234
                    True the wind sheild urethane is quite messy but if you use tape on either side of the work area you eliminate some of the mess. Also true it don't fit well into a syringe, but I usually attach some cheap tube onto the nozzle and tape a stick to the end of the hose so I can guide where the urethane gets applied. Then I use another stick with a modded end to scrape it smooth. Once done i just peal off the tape, and done :-) (I use this option more when installing a lipo systen into the sponsons of a cat) but works 100%
                    Visit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
                    "Follow someone's footsteps and you will always be a step behind"
                      Make Total Destroy
                      • Mar 2014
                      • 1952
                      #235
                      i bet the stuff works amazing, but the few windshields I've done, no matter how careful i was, somehow i would end up with it on my hand or clothes, and subsequently everywhere lol
                        Make Total Destroy
                        • Mar 2014
                        • 1952
                        #236
                        More stuff from the mailman
                        Thanks monojeff and OSE
                        • rayzerdesigns
                          • Dec 2013
                          • 1228
                          #237
                          beautiful work
                            Make Total Destroy
                            • Mar 2014
                            • 1952
                            #238
                            DF pirate 35 build
                            Thanks ray.
                            Back at it tonight. I grabbed some aluminum standoffs and filled the theads with epoxy, then re drilled for the tiny traxxas screws that come with the reciever box.
                            Basically I'm gonna glue the standoffs down so the whole box will be remove able. I know Velcro works much easier but I don't want it flipping around in there
                            Here's the bottom of the reciever box.
                              Make Total Destroy
                              • Mar 2014
                              • 1952
                              #239
                              Got the reciever box glued in and dressed up the cooler can
                                Make Total Destroy
                                • Mar 2014
                                • 1952
                                #240
                                Travis, those tabs came today. Thanks a ton dude!
                                Also, I recieved the aquarium sealant for the battery trays.
                                Reading it's description, I'm kinda liking it.
                                Check out the specs
                                Withstanding a 750 gallon tank is some serious stuff.
                                I'm excited now. It's gonna work out nicely I think
