DF pirate 35 build
Today I recieved my 24v power supply from Joel (rockstar) and some black cooling hose tossed in. Thanks Joel always a pleasure...
I took s ride to my lhs for a few things.
I did grab a traxxas waterproof reciever box, and particularly some flat cf rod to glue down before the motor mount. The small amount in height will make a huge difference in getting a wrench in there if ever needed.
Also I grabbed some larger brass to try for the servo to rudder rod. Usually I use 1/4 brass but I wanted to try larger. Turns out the boot can stretch to fit over 5/16
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
Got some work done today.
Mounted the servo, stuffing tube, brass tube and boot for steering rod, and layed two strips of cf flat rod for the motor to mount on top of
Oh and I got the jacket on the motor
Too bad the mount wasn't wider . The water entry to the motor jacket should be on the side close to the motor plate with the water exiting at the top end bell side ... So the air pocket escapes ."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert EinsteinComment
This is coming along nicely!NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Thanks.
The easiest way to make a nice black stuffing tube is to just use shrink wrap.
Because I have a gap it was easy.
The build is looking awesome, really nice work. What did you end up using as an adhesive to glue everything down? Windsheild adhesive is incredible stuff, I,ve installed a few windshields and used it on big boats. It held a fullsize 12volt marine battery mount in place in a speed boat that ran some big water, still doing the job 10 plus years later. Sikaflex is another great one, used a lot in big boats. I really like how neat you got everything installed, any good tricks for glueing everything in so nice?Comment
DF pirate 35 build
I haven't glued in the trays or motor yet.
The windshield guy that comes to my shop offered me a tube of the urethane and some primer if I want to try. Stuff is super messy tho.
The other option is black aquarium sealant. I still can't wrap my head around that tho.
When I glued in the servo and flat rod for motor mount, first I sanded some cf rod onto a piece of paper to make dust to color my epoxy.
Then I took a piece of fabric is cut the ends of if with shears repeatedly to get sort of milled cf.
then I just Mix it into my epoxy, tape off areas I don't want it, and try to use only as much as needed.
Spreading glue everywhere def doesn't help hold things in place.
Hey Luck, make sure you tape everything off really good to not get the goop all over that nice build. I use a small trash bag a lot for the hull and just cut the small hatch opening in it and tape it secure with painters tape.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Back at it tonight.
For the motor and esc mount I picked up some west 406.
To color it I sanded a scrap piece of cf Rod.
