Need a pic luck
DF pirate 35 build
--Albert Einstein -
--Albert EinsteinComment
ill get one tomorrow.
its possible the Kintec stuff shows up tomorrow. tracking says it left the shrewsbury sort facility today at 4. 30 min drive from me....
ose orders are usually fast as well, considering its 30 minutes away the other direction.
i have to stop into the store someday..There's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
I used Jb weld , then i made a small wooden wedge for the hull to the tube reinforcement . Then i wrapped it in CFK and west .Comment
More stuff today
I forgot to get the tail ring and the cf mounting plates came with No tabs?
How am I gonna mount them,,, "scratches head"
I put in another order with kintec for some more stuff including that pesky ring.
I went with 2075 servo. It's pretty quick and powerful. I've always liked them.
Here's my stuffing tube
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
More stuff today
If you need those little tabs for the battery trays I have plenty. I hardly use them.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Ide love em man.
How do you mount stuff without them tho?
Originally posted by Luck as a Constant;
Here's my stuffing tube [IMGhttp://tapatalk.imageshack.com/v2/15/03/09/73c953bc38c65ece0e9c1c295af2c06c.jpg[/IMG]
image.jpg"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
Well I could go up front or in back.
If I mount a motor in the rear, and have a short stuffing tube, is it more prone to leaking?
From my experience with df mono hulls, is they seem to not like much weight in the back. Not sure on this hull tho
I find the opposite with the weight, the cog's i run in my monos are like 28-30%. The motor placement is not that big and issue really but with forward mounted you dont have such an angle on your tube. Weight can be adjusted easily with the batts, especially with the 2p you will run. You are gonna have the batts on the sides right?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
I find the opposite with the weight, the cog's i run in my monos are like 28-30%. The motor placement is not that big and issue really but with forward mounted you dont have such an angle on your tube. Weight can be adjusted easily with the batts, especially with the 2p you will run. You are gonna have the batts on the sides right?Michigan Fast Electric SAW Club
Revolt - 76.9mph...Building a DF35- Project MonoComment
The bend is not not bad at all and lots of room to move batteries around. The batteries all the way to the rear is 27%.
DSC_0142.jpg DSC_0141.jpg DSC_0150.jpg DSC_0149.jpgComment
