DF pirate 35 build
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    DF pirate 35 build
    Well, I'm back in. Just bought a hull to start. No idea what I'll be using for hardware or electronics. I sold all my stuff last year to start fresh, so I need everything.
    When the hull gets here I'll post some pics, but for now I'm looking for any input.
    I really want to build a fast efficient boat that has good stamina. The plan is for 6s2p. That's about all I know at this point.
    Also I do prefer a stinger drive to a strut. Any thoughts?
    I've never done a boat this size so I do need some guidance on this one .
  • Make-a-Wake
    FE Rules!
    • 5557
    I'd go stinger, I'm still a big fan of the Castle 1717(45 x 85mm, 1580kv) on 6s2p, although other options would be a Leopard 4092(40 x 92mm, 1480 or 1730kv), a Neu 1527(40 x 102mm, 1500kv) or a TP4070(40 x 100mm, 1640kv) all on 6s2p of course. a T180 should handle it but a swordy 200+ amper would be nice.
      Make Total Destroy
      • Mar 2014
      • 1952
      yeah i was looking at the xo1 motor there...
      as far as the stinger goes, I've done monos with both a stinger and a strut. honestly, i didn't see any benefit to using the strut. in fact, all the strut did, was take up more space back there. ill probably go stinger, but it seems to be out of stock at ose.
      other than ose and kintec, are there any other sources for hardware?
        What do you want for speed and run time? Running 6S is a good choice for efficiency, speed and run time as long as you don't go too wild with high speed.
        Depending on on the desired speed a 40x82 to 40x92 motor with a Kv between 1200 and 1400 would work. Too many folks get hung up on high rpm when it usually means higher amp draw and not much more speed.
        It is tough to beat the SpeedMaster .40-sized stingers and rudders. The problem with stingers is the lack of much adjustability. An example - last week a club member was having trouble with his new 6S mono, it was a bit unstable in the turns and had a bit of chine walk on the straights. He raised his strut by a bit over 1/16" and solved the problems. It is literally a different boat and is now an awesome handling oval racer. This kind of adjustment is usually tough with a stinger, often requiring remounting it higher or lower on the transom. But stingers do look a lot better than struts and once set up they are great. Plus a strut may be tough to fit on the Pirate's transom.
        Whatever you decide, good luck with it. Should be a great boat!
          Make Total Destroy
          • Mar 2014
          • 1952
          thanks for the input jay \m/
          speeds i would like in the high 50's hitting 60 if possible. but more so, i would like a fair amount of runtime and cooler temps, so i would be willing to sacrifice speed to get there. I'm just not sure what reasonable expectations are in regards to speed vs runtime...
          as far as the stinger vs strut goes, i feel like i need a flooded chamber with a strut to get any up down movement. at least thats how i built my df26, causing motor placement to be kinda stuck. I'm really not sure where to put the motor on this thing. I've in the past always had them way up front. in any event, If i am to do a stinger, i would be mounting it up a few mm for the bottom. maybe even 1/4"? i think on my Titan 29 i had it up 4mm or so and that boat ran awesome. much nicer look too.
          • Make-a-Wake
            FE Rules!
            • 5557
            I get right at 60mph with my 39" mono on 6s2p running the Castle 1717, stinger, and x548 on 6s2p......................never gets hot. Runs perfect. You can set it up to run low-mid 50's, that may be a better "zone" for that hull.....................but you know how we push 'em
              Make Total Destroy
              • Mar 2014
              • 1952
              Castle motors are great aren't they? seriously, for the money they're awesome. never tried a TP.
              Whats the difference between the x01 and the 1717 tho?
                Make Total Destroy
                • Mar 2014
                • 1952
                has anyone tried these? http://www.offshoreelectrics.com/pro...prod=ose-83022
                they look glorious
                • Make-a-Wake
                  FE Rules!
                  • 5557
                  Nothing except the Car version is 1650kv, Your hull isnt as wide as mine and needs a prop in the 42-45mm range imo so a few more rpms wont hurt. I did mention a 4092 1480kv if you want a bit lower.
                    Make Total Destroy
                    • Mar 2014
                    • 1952
                    thanks for the reply :yes way:
                    i did notice ose sells a cooling jacket for a 1717 and xo1 motors separately tho.... there must be a size difference?
                    • Make-a-Wake
                      FE Rules!
                      • 5557
                      I dont think you need that much trim tab width, those will take up 5" of your transom as well...............these may be an option
                      http://www.offshoreelectrics.com/pro...prod=ose-80925
                        • 7673
                        Yay, I am so down with this build. IMO XO-1 motor on 5s for sportin'. My 1580kv 1717 runs pretty good on 5s with 447 or so prop. I also run on 6s with same prop mind you.
                        I am running these tabs and only needs bit of them to level it out.
                        Guess I should add that I have the DF 35"
                          Make Total Destroy
                          • Mar 2014
                          • 1952
                          or these sexy EDIT http://www.offshoreelectrics.com/pro...d=ros-spdt-502
                          • Make-a-Wake
                            FE Rules!
                            • 5557
                            Originally posted by Luck as a Constant
                            Whoa! some serious machinery there, freakin thick...................... the width is much more appropriate
                            I'm gonna look up your hull to check the width, just curious......
                              Make Total Destroy
                              • Mar 2014
                              • 1952
                              i used these on my titan 29 and they worked quite well.
                              http://www.offshoreelectrics.com/pro...prod=ose-80070
                              titan is 10.5 wide
                              pirate is 10.25 wide
