DF pirate 35 build
NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
I should post some pics.
Used wax paper to make a templet on the cf
And test fit
I'll be doing two layers
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
I'm not sure on that...
No idea on that.
The only thing I can say it that there is a very small difference in length and width of them. So small I would be inclined to say that it's only because the top decks are different.
However, looking at pictures of the two, the pirate looks a bit deeper V, but it's impossible to tell from just a picture
The Pirate is a bit taller and deeper vee. Looks awesomeNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
From studying the pics, I'm pretty sure the bottoms are the same. The Pirate looks deeper because of the little extra freeboard and that's what makes the difference in the length and width.Comment
That inlay looks great! What grit do you use to sand the hull down prior to laying in the cf? Also, since you're doing 2 layers, have you thought of just getting 6k cloth instead? Just a suggestion as that'll save you time and it's easier to work with.Comment
I used 180
No I hadn't thought about heavier cloth. I just got some good easy to use cloth. I'll consider that in the future thanks!
If you want to do a nice job, it's necessary to have the rite materials.
A bit costly, but worth it.
DF pirate 35 build
Guys, if you aren't using west systems 105, I highly recommend it. I've used zpoxy for years and never has it been this easy and good looking....
It's all I use....Really makes a difference."There's nothing else I really want to do other than get up and build boats." - Mike FioreComment
