DF pirate 35 build
  • TheShaddix
    • Sep 2013
    • 759
    #91
    Thanks on that sandpaper advice! I also find the wood sandpaper doesn't really scuff it up enough.
    And if you like the pumps, all good. I just can't bring myself to use them knowing there is a chance of ratios not being exact. You should do a test and weigh it once you're done pumping to see how accurate the pumps are. It would be interesting to see. I'm sure the pumps work great for big jobs as a small variations in ratios then are not as critical. As this epoxy system was designed to work on real scale boat repairs and whatnot, mixing large batches at a time, what if you need to mix just 1oz of epoxy for some important connecting fillets for your motor mounts and are slightly off on your ratio without even knowing it... The epoxy either ends up a bit too flexible or too brittle. And a mistake like that could kill a whole build. That's just my thoughts on it. Not trying to say the pumps are junk. Just seems a bit too crude of a method for small batches.
    • Luck as a Constant
      Make Total Destroy
      • Mar 2014
      • 1952
      #92
      Yeah it's def not for making small batches.
      For small jobs I just use a different product like jb weld or 5 minute
        Make Total Destroy
        • Mar 2014
        • 1952
        #93
        It's not like you can't just pump some into a measuring cup anyways for s small batch
          Make Total Destroy
          • Mar 2014
          • 1952
          #94
          Some of the hardware showed up today.
          • Make-a-Wake
            FE Rules!
            • 5557
            #95
            Bling!!!!!!!!!!
            BTW, i use Traxxas 2075 high torque waterproof servos in alot of my boats and they work very well.............
              Make Total Destroy
              • Mar 2014
              • 1952
              #96
              Ohgodya.... Speed master hardware is just fantastic!
              Yes the 2075 is excellent.
              This rudder blade is a lot wider than expected. Gonna be a lot of force when turning...
              • Make-a-Wake
                FE Rules!
                • 5557
                #97
                That's another reason I suggested the tapered...........
                  Make Total Destroy
                  • Mar 2014
                  • 1952
                  #98
                  I thought I did get it but I must have hit the str8 blade.
                  Oh well it's ok I'll use it
                    Make Total Destroy
                    • Mar 2014
                    • 1952
                    #99
                    I think it's more the fact that I've always built 27-29" boats, so I'm not used to the larger stuff, but up against the boat it doesn't look oversized or anything.
                    Today I recieved the amg logos from Joel "thanks Joel"! So I masked it up to blast some paint on it.
                    I did the transom last night with 3 layers of cf.
                      Make Total Destroy
                      • Mar 2014
                      • 1952
                      #100
                      • Savage Skidoo
                        • May 2011
                        • 332
                        #101
                        I have swapped out the 2075 for the savox mg 231 , never looked back !IMAG0361.jpg
                        www.facebook.com/Boaters and Crawlers Durham
                        Durham Off Road Rc Club - www.dorc.ca founding member
                          Dont know if these guys even sell anymore.........I'm not setting up an account to see..........but here's one.
                          http://fightercatracing.com/index.ph...art&Itemid=97#
                          I have one of these mounts if you need it.
                            Make Total Destroy
                            • Mar 2014
                            • 1952
                            #103
                            Thanks Travis I'll let you know.
                            Is it brand new? How much?
                              Make Total Destroy
                              • Mar 2014
                              • 1952
                              #104
                                Originally posted by Savage Skidoo
                                I have swapped out the 2075 for the savox mg 231 , never looked back ![ATTACH=CONFIG]128431[/ATTACH]
                                i use these servos in just about everything. very good servo for the money.
