New P Sport Hydro 2015!
  • detox
    • Jun 2008
    • 2310
    #61
    P/Q Shooter...................a little longer and it would qualify for both P (34" max) and Q class (34" minimum)
    It would be interesting to see which is faster...P or Q.
    • detox
      • Jun 2008
      • 2310
      #62
      P Mature Shooter
      • Shooter
        Team Mojo
        • Jun 2009
        • 2520
        #63
        Ha! Nice. Man, those whips look great, D!! They were the inspiration for using the UL-1 cowl on my last three builds. I also love the way the back tapers down on the whip (tapers WAY down on your extended version).
        • ron1950
          • 3024
          #64
          I think P-SHOOTER is the way to go and if u ever start building them for others put me in the line
          • darryl whitman
            • Sep 2012
            • 535
            #65
            hay Shooter, frame built an going to start placing bottom skin on. day 2 of the 30 day build, LOL
            really got about 7 hours in it so far. if u dont mind, I'll Email you some ideas ? she 's a good build.
            • Fella1340
              • May 2013
              • 1025
              #66
              Great looking design and dedication to builder better all the time. I look forward to seeing how the changes improve things over the last version. Great work!
              • longballlumber
                • 3119
                #67
                Are you planning on sharing any pictures of your build? Inquiring minds want to know.
                Later
                Mike
                • darryl whitman
                  • Sep 2012
                  • 535
                  #68
                  Oh ya, Here we go, the framing was easy. just make sure you run a straight center line on your build table an follow
                  the line up marks Shooter placed on the frame. Once I got that done , I placed the frame on top of the bottom skin
                  an traced around the frame to place glue, then set frame on it and placed weights on top. then I put 2 oz fiberglass
                  down in the center area front to back, with westsystem epoxy. here's some pic'sS7301094.jpgS7301096.jpgS7301098.jpgS7301100.jpgS7301104.jpg
                  • longballlumber
                    • 3119
                    #69
                    Nice,
                    Thanks for sharing!
                    By chance can you get a weight on it once everything cures?
                    Later,
                    Ball
                    • Shooter
                      Team Mojo
                      • Jun 2009
                      • 2520
                      #70
                      Cool. Thanks for sharing Darryl. Are you going to double up that transom? Did you use the 'dummy' motor mount prior to tacking? Did you use the jig? Thanks!
                      • darryl whitman
                        • Sep 2012
                        • 535
                        #71
                        Shooter I am going to double the transom an add 1/8 " marine ply also. No to the dummy motor mt.
                        yes with the Jig, thats a good idea. I tack glue in in 6 spots easy to cut away , also on the bottom skin where
                        it angles up at the main double frame, I scored the skin so it would bend easy to glue up. when or if you try this
                        score the inside of the skin right in front of the doubler frame , make it a V cut half way.
                        this may help too, on the transom you have a center mark, cool I also placed marks on each end ( right an left ) sides
                        the same measurements of the first rear bulkhead, I glued a 1/16" sq stock up right on those marks to glue the inner frame to transom. you may be able to see it in my pics .
                        • longballlumber
                          • 3119
                          #72
                          Should be a screamer Darryl!
                          Later,
                          Ball
                          • Shooter
                            Team Mojo
                            • Jun 2009
                            • 2520
                            #73
                            That's a good idea to score the bottom with a 'v' for an easier bend. How deep do you go? One ply? Thanks.
                            • darryl whitman
                              • Sep 2012
                              • 535
                              #74
                              I try to go half the thinkness, you can do this on a table saw with a fine thin blade.
                              Shooter, what r u using for the nose on the boat?
                              • ray schrauwen
                                • 9438
                                #75
                                Great stuff in here, me likee!!
                                Nortavlag Bulc
