New P Sport Hydro 2015!
  • Shooter
    Team Mojo
    • Jun 2009
    • 2558
    #271
    Paint prep. I signed out the paint booth for tomorrow morning. We'll see how she goes. Going to try a different gun this time.
    • rightturnonly
      • Jan 2009
      • 143
      #272
      Pete,
      Looking good!!! What's the paint scheme? and when ya putting it up for sale? ...I got room down here in the warm weather...
      JOHN A. GROSS
      MILLBROOK, AL
      Crickety Crack Racing Team
      • Shooter
        Team Mojo
        • Jun 2009
        • 2558
        #273
        People were asking about how I paint things (I'm not a painter, but I've had some mild success). At this point I've brushed it, vacuumed it, hit it with air, and cleaned it with acetone two times. I will clean once more with KlassKote reducer when I get to the shop.
        Going to use the forum to think through the paint application. Oh, and one of these things on the turn fin mount (photo) works good for hooking and maneuvering while painting.
        Believe it or not, there is actually a method to the madness to avoid overspray on finished surfaces:
        1. Spray transom.
        2. Spray front and tips of sponsons.
        3. Spray backs of sponsons.
        4. Spray sides.
        5. Spray bottom.
        6. Spray top.
        To sum it up, the entire operation is an absolute pain in the a$$.
        • Shooter
          Team Mojo
          • Jun 2009
          • 2558
          #274
          Originally posted by rightturnonly
          Pete,
          No clue yet on the scheme. I was actually thinking about sending the original black one down to you to live with it's big brother.
          • flraptor07
            • Aug 2013
            • 2451
            #275
            Originally posted by Shooter
            Turnfin brackets mounted.
            Pete are you using the Insane fin and bracket?
            • rightturnonly
              • Jan 2009
              • 143
              #276
              I'm still waiting on some decent weather on my days off down here to get big brother wet. Always seems to be raining. Finally picked up an esc for it..I'm trying to pickup boats for different classes so when I make trips I can run more than just one or two.
              JOHN A. GROSS
              MILLBROOK, AL
              • detox
                • Jun 2008
                • 2318
                #277
                Adding a tad more than recommended reducer to paint will help reduce overspray. Spray a medium tack coat on first coat to prevent runs on finish coat.
                This is how I hung boat using woodscrew in nose. I added long screws in transom to turn hull by hand while painting. Paint booth helps, but not really needed...bugs, dust, hair and other debrie can be color sanded out later.
                • Shooter
                  Team Mojo
                  • Jun 2009
                  • 2558
                  #278
                  Chris - I've been making all of my fins and brackets lately. Took me awhile to figure out what worked, but I think I got it down now.
                  D - That yellow boat looks beautiful. If I remember, you were using two part automotive paint, correct?
                  • Shooter
                    Team Mojo
                    • Jun 2009
                    • 2558
                    #279
                    Both boats are in primer. I tried this new cheapo harbor freight detailing gun (0.6mm), @ 40psi. Using Klasskote, I mixed 1:1:1 (part A: part B: reducer). Turned out good. I'm happy with the new gun. It's a challenge to get a 'wet' coat on with the reduced flow of the 0.6mm, but it's far less waste than the bigger gun. I'm going to stick with it for the next coat. A lot of sanding to do.
                    • Shooter
                      Team Mojo
                      • Jun 2009
                      • 2558
                      #280
                      BTW, here is the ludicrous conglomeration of $hit that you need to paint. Counting the 2 hours of prep Thurs night, the taping, the driving to the shop, the mixing, etc... it took 6 hours to get the first coat of primer on. Not for the un-patient. (and I still managed to fix a toilet and hang curtains today!)
                      • flraptor07
                        • Aug 2013
                        • 2451
                        #281
                        [QUOTE=Shooter;617516]Chris - I've been making all of my fins and brackets lately. Took me awhile to figure out what worked, but I think I got it down now.
                        LOL ok Pete, but that really didn't help me, Let me ask you this. What did you figure out works? And have you used the Insane FE30 fin?
                        • Shooter
                          Team Mojo
                          • Jun 2009
                          • 2558
                          #282
                          The insane fin seemed a little small to me. Never tried it though, but I've heard they work well on the FE30. I've found that a consistent width fin (just as wide at the bottom as the top) with an aggressive curve towards the very bottom (not a gradual curve from midway down) works best. Oh, and it has to be as thin as possibleand sharpened with a gradual taper at least 3/4" into the blade. Just my experience. We played around with these last year (probably about 50+ runs with different fin designs).
                          • jfrancisco892
                            • Feb 2012
                            • 546
                            #283
                            Late aggressive hook on the fin seems to work good with what I've experienced. Depth and leading edge angle is also important. Experiment with it and you'll figure out what works. I've probably tried 5 or so different fins on my Whiplash
                            • flraptor07
                              • Aug 2013
                              • 2451
                              #284
                              Thanx Pete, looks like I'll be makin' some fins, But I do have a FE30 fin coming. I bought a complete FE30 hardware kit.
                              I'm goin' through the same thing right now with my GP400, I think I've had 4 or 5 different ones on it so far. It seems to like a angled fin better than a curved fin.
                              • longballlumber
                                • 3132
                                #285
                                Are you running 2 boats in P sport hydro? (why are you painting 2 hulls)
