  • masonis1
    If you cant control it 👍👍
    • 1173
    #61
    Ok well i have some line i could use. Its 1/8 inch rod. Its strong stuff i got at my hobby store. Could this work or would i need something else?
      • 7651
      #62
      I think your best bet will be getting the kit that I posted by octura.It was $63 or so and comes with a flex cable,Fine's does not.The only thing you would need is a drive dog and prop.There are some options there as well, IE:Prop shaft size.
      • masonis1
        • 1173
        #63
        For props, i have some from offshore, they are plastic props. They are cheap but all a different color and different pitch. I cant look them up on my phone but if you guys can that would be cool and let me know what size drive dog i need etc. I have the props at my grandpas garage where i was working on this boat. So i found a strut and/or a stinger for about 10 bucks. So im at 18 bucks? Why is the kit a better bet, sorry im a teenage guy that doesnt have much money.. hah
        • masonis1
          • 1173
          #64
          Found this i might need to look at..
          Same thing i think... Would this work?
            • 7651
            #65
            You're gonna need this http://www.offshoreelectrics.com/pro...od=oct-oc64pkg and a stuffing tube(brass tube) to go along with that e-bay setup.So the flex is another $23
            • masonis1
              • 1173
              #66
              Could i get any of this at my lhs?
              • Make-a-Wake
                FE Rules!
                • 5554
                #67
                Go with a strut like this....................cheap and easy. You will need a flexshaft as well..............dont know the size but I think its 3/16.......either that or 4mm.
                http://www.offshoreelectrics.com/pro...qub7881&cat=76
                Here's where i suggest the drive hole to go..........and where the rudder should be
                • masonis1
                  • 1173
                  #68
                  Ok. Thanks for the picture. Will that rudder/strut i showed earlier work?
                    • 7651
                    #69
                    I got to learn how to do that with a pic M-a-W.
                    I doubt that you'll find any boat stuff except a RTR boat at the LHS.That is the way it is around here anyway.You could check.
                    Now you see why that one complete kit is worth it,the SV strut is $22,and still needs stuff,the cable is $23 and you still need a rudder.The kit will for sure all fit together eliminating further issues.Only need a drive dog,best as I can see.
                    • masonis1
                      • 1173
                      #70
                      Ok i will save up and get that kit. Hope it works. If any of you find a cheaper kit,c that would be GREAT
                      • masonis1
                        • 1173
                        #71
                        The rudder and strut I found email I can buy it now for 20
                          • 7651
                          #72
                          The only thing with that setup is a serious lack of info.They don't say if it is for a 4mm shaft or 3/16.
                          • masonis1
                            • 1173
                            #73
                            I will ask the guy and find out. What should i ask him? Any info i need to ask for?
                              • 7651
                              #74
                              I did some research and best that I can tell is it is 4mm.My concern was the bushings but it looks as though they would come installed. You can get a 4mm shaft that is stepped down to fit 1/8 props which is probably all you will need.Also probably what you have.
                              • masonis1
                                • 1173
                                #75
                                Oh great. Sounds good. So this would work fine?
