TFL Hobbies "Popeye" Hydro: P-Sport Hydro
  • Doby
    KANADA RULES!
    • 7280
    #586
    One thing I did this winter was to move the water outlet to the top of the boat vs exiting out the side....it should be easier to now see the water flow....of course I won't be able to tell for another couple of months.
    Grand River Marine Modellers
    • tlandauer
      • 5666
      #587
      Yup, great idea! Might have to do that, the more I think about the temp issue of yesterday the more I suspect that the flow was somehow restricted.
      Too bad the water is open and I haven't the down time to do the modification.
      • Jlov
        • Nov 2013
        • 825
        #588
        Got bored while waiting on new ESC to come so decided to seal the hatch so I don't have to use hatch tape anymore. Used some 1/8" closed cell sponge tape and some 1/4" chrome socket cap screws with neoprene washers. Took rest of electronics out and turned boat upside down and pushed it under water in tub and not a drop got inside. It's water tight. Saw this done by Keith Bradley in a thread on here and I HATE hatch tape!!
        • Jlov
          • Nov 2013
          • 825
          #589
          • RandyatBBY
            • Sep 2007
            • 3915
            #590
            Oh so you are a hatch tape Rebel.
            Randy
            BBY Racing
            • Jlov
              • Nov 2013
              • 825
              #591
              God yes and it's not just the annoyance of having to tape it and un-tape it each time. It's the glue residue it leaves on my pretty paint job...
              • lenny
                • Sep 2010
                • 4294
                #592
                Nice job on the seal,
                That is what I try to do to all my boats.
                It just makes it so much easier to get in and out of the hull,
                For testing speeds and temps of the setup.
                ? ONLY IF THEY WORK
                • Jlov
                  • Nov 2013
                  • 825
                  #593
                  Yea used some socket cap screws for now. I have some nice small black anodized thumb screws coming in mail from Fastenal.....
                  • Jlov
                    • Nov 2013
                    • 825
                    #594
                    Got my new ESC installed and programmed. Did a bench test all seems well. Got a new boot on to correct leaking spot. Will get it in water in morning for first run. I'll try and get some video. It's maiden voyage ended in a ESC fire so hopefully tommo goes better
                    • tlandauer
                      • 5666
                      #595
                      All the best!
                      HATCH RETAINERS LOOK GREAT!
                      • Jlov
                        • Nov 2013
                        • 825
                        #596
                        Lol thx Tim. Just looking over my setup now. Is top of rigger flush with top of rigger bracket on yours? Thx Jeff
                        • tlandauer
                          • 5666
                          #597
                          Yes, flush. I raised it for the latest run, buy start this position, you don't want it to run too dry first.
                          Sent from my Droid using Tapatalk 2
                          • Jlov
                            • Nov 2013
                            • 825
                            #598
                            Yea and I'm using the y547 prop. I'm also hoping I have my turn fin at 90* after I put the shim in......
                            • eboat
                              • Aug 2007
                              • 693
                              #599
                              Looking at your picture
                              When you slide the flex shaft into the boat do you have to push it to one side to get it to slide into the collet ?
                              Looks a little bent to one side
                              • Jlov
                                • Nov 2013
                                • 825
                                #600
                                I do not have to push flex cable over at all when I slide flex cable in. It was my first stuffing tube install and I did notice it was not exactly lined up. During bench test yesterday shaft seemed to be rotating freely without any binding. I would hate to have to re-install this stuffing tube. Will this be a problem? Thx Jeff
