okay i am placing an order and i wanted to replace my 642 but they are out of stock, is the GrimRacer Metal Prop 42mm Diameter x 66mm Pitch pretty close? I still have the 645 but still not sure about that much prop. Last run out I spun the dog drive so I did not get much run time. my new 5300 60C packs are in so I hope that helps even with the stock setup over the 5000 45C
What is the deal 43MPH still?!?!?!?!?
Really? I'd like to see a Spartan doing upper 60's..............stable?? I have seen so many Spartans run like they are gonna flip onto the side is why im asking. Any vid of it?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
http://forums.offshoreelectrics.com/...est!&highlight=Comment
I'm at work and the youtube link is blocked............
yes i did just fine tuning the trim tabs and make the bottom of the ridgid that was the v1 hull my v2 hull was easier to tame i have other vids of it in the 60's also that cc1515 had alot to do with it getting those speeds
but that motor was a no no on 6s from what i hear but it worked good for me
Im Only Responsible For What I Say Not For What You Understand
Its a dual pickup rudder from kintec it was longer than stock that stabled it out also to be honest the tabs wasnt even touching water at speed
Sent from my DROID RAZR using Tapatalk 2Im Only Responsible For What I Say Not For What You Understand
i am willing to try anything at this point, i mean i went from stock 6s with 215 to the 4090 1430 with a 645 moved the batteries all the way end to end and still the same speed?!?!? i do think my batteries were not up to snuff but i got new ones but i have not had a chance to try them.Comment
