What is the deal 43MPH still?!?!?!?!?
  • MAMBA2200
    I need a scooby snack
    • Jul 2012
    • 1196
    #61
    batteries make a big difference what about your strut where is it set
    Im Only Responsible For What I Say Not For What You Understand
    • traeside
      • Aug 2012
      • 190
      #62
      i have tried up 2 up 1 and 0 is this the rudder? 5 Inch Rudder Short Base w/ Dual Water Pickup
      • traeside
        • Aug 2012
        • 190
        #63
        and then it looks like you carved it to fit?
        5 inch Rudder Offset Base w/ Dual water pickup CNC machined aluminum rudder and mounting bracket with dual water pickups and servo arm. Brass bolt for kickback protection.
        5 inch (128mm) from bottom of mounting bracket to rudder tip.
        3 5/8 inch (94mm) from transom to leading edge of rudder.
        Transom foot print is 1.7" (43.4mm) wide and 1.26" (32mm) high.
        Rudder width tapers from 1 1/4 inch to 1.1
        Servo arm w/ 2mm swivel. All stainless steel locknuts, bolts and washers included. $27.00 each
        • MAMBA2200
          • Jul 2012
          • 1196
          #64
          yep thats it and you do have to cut the mount a bit here is my v2 you can see the cut mount DSC02047.jpg
          • Make-a-Wake
            FE Rules!
            • 5554
            #65
            Why cant you just mount the rudder bracket base right around the blue boot...............there's room to move it down a bit. Surely the hole under the boot isnt that big..................use a smaller boot if you have to.
            • MAMBA2200
              • Jul 2012
              • 1196
              #66
              Well you have to use the original tubing hole for the corner bolt in this rudder i have seen the bracket turned to the other side
              • traeside
                • Aug 2012
                • 190
                #67
                i like it, i am sure i can make something work. it also looks like your tabs are closer to the bottom of the hull then stock? hey Make-a-wake wait tell you see the glass he gets to run on.
                • MAMBA2200
                  • Jul 2012
                  • 1196
                  #68
                  its not always glass if it had been glass that day i think i could've hit the 68mph lol and they are closer to the strut than stock there was a guy from Australia seen my video and wanted to buy that boat said he would give me 1600.00 to buy it and ship it to him so i did i would have been crazy not to lol
                  • Make-a-Wake
                    FE Rules!
                    • 5554
                    #69
                    Actually slight ripples/chop will make it run faster....................gets it "up" a bit.
                    I will check the vid when i get home shortly, looking forward to seeing it
                    • traeside
                      • Aug 2012
                      • 190
                      #70
                      go look at some of Make-A-wakes videos, i would not wakeboard much less run by R/C boat in some of the chop i have seen his Spartans in. LOL
                      yeah why not.
                      • traeside
                        • Aug 2012
                        • 190
                        #71
                        Okay so I got my rudder, I haven’t had a chance to run it but I had it milled out to fit around the boot.
                        • traeside
                          • Aug 2012
                          • 190
                          #72
                          Okay all mounted up.
                          • Niky
                            • Sep 2012
                            • 61
                            #73
                            Hi Guys,
                            one observation:
                            watching the videos of Spartan and other brushless boats, I had an impression that the splash that comes out from the cooling outlet on Spartan is very poor.
                            Unlike on the other boats that has more rich splash, the difference is considerable especially when you watching it in the slow motion.
                            Maybe it's one of the reasons of cooling issues that even new upgraded Castle Spartans has.
                            I burned the stock ESC on 6s, but before it happened the boat stopped for a few times (overheating cuts).
                            Yes I think that my ESC died from lots of temperature.
                            But i'll buy by OSE store the new 180A ESC with Leopard 1600kv motor, at least they say that is the winning combination for 6s on Spartan.
                            If somone could recommend me please which prop. cable to buy by OSE store. It's another issue with burnning collet couplers, I succeeded to burn it too.
                            Thank you Guys, salute all Niky.
                            • traeside
                              • Aug 2012
                              • 190
                              #74
                              Niky,
                              I am sorry to hear you burned up your ESC. Yes that is a good combo. The water outlet is a bit small I drilled mine out but the bigger issue is the pickup I would recommend a duel pickup and separate the cooling systems. If you want to save a few bucks just get a separate pick up. then drill out the fittings on the stock rudder and then also widen the pickup itself there are many how to articles here on OSE. I used the Wohlt .187 wire drive be sure to get the 10/24 nut and the 3/16 by 5/16 dog drive. Also don’t forget to make a flat spot for the setscrew to grab. As for props you can try a Prather 220 and a Octora X442 and work your way up.
                              here are 2 shots. i also added extra cooling to the ESC.
                              • dana
                                Banned
                                • Mar 2010
                                • 3570
                                #75
                                All the cooling in the world isn't gonna help if the setup is wrong
