Miss Geico Lets see what this thing can do!
  • wilsta67
    • Feb 2011
    • 203
    #271
    Originally posted by 26missgeico
    wilsta67 wish you lived in washington so i could show u 50mph at 1/4 throttle
    so can i run my 3's lipos with the castle creations 240a esc
    so what im hearing is i need to get smaller batteries with a 180a esc correct??
    yes smaller batteries 2s you will need 2 of them to, make it a 4s set up. and get a smaller prop as well or you will create to much amp draw and you will also blow up your esc because of this. get the x442 prop the one you are using is way to big.
    with the set up im using i still can not use full throttle in a straight line you will be surprised.
    • Rumdog
      • 6453
      #272
      No, you cant. 2200kv is WAY too hot for 6s.
      • wilsta67
        • Feb 2011
        • 203
        #273
        get a set of turnigy there cheap and do just as good of job these are the ones i use they come with bullet connectors but i like to use the traxxas connectors only because i have a heap of them sitting around, but they can be difficult to soldier on to the 8 awg leads if you dont no how.
        http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
        • 26missgeico
          • Aug 2011
          • 61
          #274
          ok so my next question is can i use the castle creations esc with my batteries i have now...the 3's lipo's
          • wilsta67
            • Feb 2011
            • 203
            #275
            as rumdog said before no you cant because your motor is to high kv if you changed your motor to a lower kv like a 1500kv or less then yes you can use the batteries so its a catch 22 keep motor and change batteries or keep batteries and change motor and cooling jacket
            • 26missgeico
              • Aug 2011
              • 61
              #276
              ok thanks a lot every one who helped me, appreciate it
              • 1truckerdan
                • Aug 2011
                • 329
                #277
                Are you using the esc from an e revo?
                When you know it all.......you never will learn anything new
                • LarrysDrifter
                  Big Booty Daddy
                  • May 2010
                  • 3278
                  #278
                  Was there even a GPS in the hull on the "50" mph run? Speeds are deceiving by eye. If you're using a 2200kv motor, which you have, you don't need a 240amp speedo-unless that's just what you want. There is nothing to gain from it. You should get TWO 2s 5000 mAh 40-50c packs and run them in series. Or, buy TWO 4s 5000mah 40-50c and run them in parallel. Read the Miss.Gieco threads to get you going on a prop size. Simple. There's your answers.
                  • 26missgeico
                    • Aug 2011
                    • 61
                    #279
                    ok well no im not using the e-revo esc,, no i did not have it gps ed i got some venom 5000mah 7.4v 40c i think ill try.. can i use my motor if i get a 240a esc if i run the smaller batteries?
                    • JPriami
                      N4FOX
                      • 1675
                      #280
                      You can use your motor with another 180 esc on two 2S packs in series to make 4S. Or two 4S packs in parallel for greater mAh that equal 4S. With a x442 prop and you should be good to go
                      • LarrysDrifter
                        Big Booty Daddy
                        • May 2010
                        • 3278
                        #281
                        Yes. You should get the 240amp esc. I'd get a Castle or a Schulze esc. If getting a Castle, post a WTB for 240hv, not the new Hydra Ice. Good luck to you.
                        • 26missgeico
                          • Aug 2011
                          • 61
                          #282
                          hey man any help i appreciate it
                          • LarrysDrifter
                            Big Booty Daddy
                            • May 2010
                            • 3278
                            #283
                            No problem. The new Hydra Ices aren't proven. Get the older 240hv. They never blow.
                            • 26missgeico
                              • Aug 2011
                              • 61
                              #284
                              ok now what if i get a 240a or the 180a esc and run my same batteries but if i run it in parallel would i be able to run my old lipos (3's)
                              • LarrysDrifter
                                Big Booty Daddy
                                • May 2010
                                • 3278
                                #285
                                Yep. Get the 240 and you can use any packs you like.
