I laid a piece of tape then siliconed it to the tape so I could test it. It's glued permanent now. Im adding one to the zelos today.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
good possibly, since there only held with 1 adjustment. I read manual { very good one} and holding the rulers were hard to do, so I had 1mm stock brass strips, measured stock and they were just under 4mm from last too ride surfaces, {were not even, I flipped it once before doing this, so may have moved} I soidered 3 X mm strips of brass together and held ruler on last too ride surfaces and dropped them 1mm each. Hope that helps in messuring yoursZelos 36 stock 68 mphComment
Batteries all the way in front will help with the boat not lifting. I would say to run your strut at a neutral level but that would probably cause more lift so I don't know what to tell you. I got 71 mph with stock electronics , x447 props s&b, batteries all the way forward and rudder has not been sharpenedComment
Ahh. Great idea. I mentioned doing it to the guys at my pond, and one good racer mentioned that I should leave almost 1 inch from the sides, in other words, not go all the way across, said it needs some funneled air through it, in thinking turns. What do you guys think?Zelos 36 stock 68 mphComment
the rudder came pretty ugly. I could run my short ass fingernail on it and at end, was big ledge, {lack for a better word} ran my finger down the rudder and nothing but ripples. So I sanded it smooth, sharpened it. Im thinking it may need that lag. Anyone else has got a "rough" looking rudder, before I order a new stock one?Batteries all the way in front will help with the boat not lifting. I would say to run your strut at a neutral level but that would probably cause more lift so I don't know what to tell you. I got 71 mph with stock electronics , x447 props s&b, batteries all the way forward and rudder has not been sharpenedZelos 36 stock 68 mphComment
running SMC batteries and water had a slight chop, even down windBatteries all the way in front will help with the boat not lifting. I would say to run your strut at a neutral level but that would probably cause more lift so I don't know what to tell you. I got 71 mph with stock electronics , x447 props s&b, batteries all the way forward and rudder has not been sharpenedZelos 36 stock 68 mphComment
Do you mind taking a picture of what you are using to do this? I tried the two rulers as well but may be off, kinda hard to say.good possibly, since there only held with 1 adjustment. I read manual { very good one} and holding the rulers were hard to do, so I had 1mm stock brass strips, measured stock and they were just under 4mm from last too ride surfaces, {were not even, I flipped it once before doing this, so may have moved} I soidered 3 X mm strips of brass together and held ruler on last too ride surfaces and dropped them 1mm each. Hope that helps in messuring yoursProboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
rough example.. 1mm shims may not be "exactly" 3mm once together, but as long as both the same, don't matter if there 2.97mm or not. you need wife to help hold ruler :)
ofcourse prop and shaft removedZelos 36 stock 68 mphComment
