    How in the world are you guys getting to those speeds with the X447, I can barely make it out the 50s. Im beginning to think after my wreck that maybe the struts got moved.
    Have you sharpened your rudder?
      Originally posted by Team Lucas
      only hit low 60,s and not full throttle before it wanted to lift {I was running with the wind} I,m Def trying it out for next sundays run. Looks like you just taped it on?
      I laid a piece of tape then siliconed it to the tape so I could test it. It's glued permanent now. Im adding one to the zelos today.
      • Team Lucas
        • May 2016
        • 300
        #648
        good possibly, since there only held with 1 adjustment. I read manual { very good one} and holding the rulers were hard to do, so I had 1mm stock brass strips, measured stock and they were just under 4mm from last too ride surfaces, {were not even, I flipped it once before doing this, so may have moved} I soidered 3 X mm strips of brass together and held ruler on last too ride surfaces and dropped them 1mm each. Hope that helps in messuring yours
        Zelos 36 stock 68 mph
        • paulfromtulsa
          • Nov 2013
          • 211
          #649
          Batteries full forward, and 1mm down struts. Sharpened and smoothed rudder tho, maybe lessened the drag in back?
          Batteries all the way in front will help with the boat not lifting. I would say to run your strut at a neutral level but that would probably cause more lift so I don't know what to tell you. I got 71 mph with stock electronics , x447 props s&b, batteries all the way forward and rudder has not been sharpened
          • Team Lucas
            • May 2016
            • 300
            #650
            Ahh. Great idea. I mentioned doing it to the guys at my pond, and one good racer mentioned that I should leave almost 1 inch from the sides, in other words, not go all the way across, said it needs some funneled air through it, in thinking turns. What do you guys think?
            • Team Lucas
              • May 2016
              • 300
              #651
              the rudder came pretty ugly. I could run my short ass fingernail on it and at end, was big ledge, {lack for a better word} ran my finger down the rudder and nothing but ripples. So I sanded it smooth, sharpened it. Im thinking it may need that lag. Anyone else has got a "rough" looking rudder, before I order a new stock one?
              • Team Lucas
                • May 2016
                • 300
                #652
                running SMC batteries and water had a slight chop, even down wind
                • Keagan-Z06
                  • Mar 2016
                  • 970
                  #653
                  Yup did that!
                  • Keagan-Z06
                    • Mar 2016
                    • 970
                    #654
                    Do you mind taking a picture of what you are using to do this? I tried the two rulers as well but may be off, kinda hard to say.
                    • Keagan-Z06
                      • Mar 2016
                      • 970
                      #655
                      Running the same packs, are you running 2 or 4?
                      • Team Lucas
                        • May 2016
                        • 300
                        #656
                        sure give me a bit, just put everything up, and im running 2 x 3s
                        • Team Lucas
                          • May 2016
                          • 300
                          #657
                          rough example.. 1mm shims may not be "exactly" 3mm once together, but as long as both the same, don't matter if there 2.97mm or not. you need wife to help hold ruler :)
                          ofcourse prop and shaft removed
                          • Erroneous
                            • Apr 2016
                            • 451
                            #658
                            I use my allen wrenches. Have thought about making a jig though. In the butter zone for my setup untill I change props again (soon). Till then its just moving my batteries around for ballance.
                            • Keagan-Z06
                              • Mar 2016
                              • 970
                              #659
                              Dang right strut was off by 1mm and left strut had 0mm gap.
                              • paulfromtulsa
                                • Nov 2013
                                • 211
                                #660
                                [ATTACH=CONFIG]144011[/ATTACH]
                                Strut level makes a ton of diffrence in speed. Get it leveled off and you will go a lot faster
