Thanks man, I must have just had an unlucky Voracity as since day one it got water even though I taped the hatch. I since then silicone screw but I won't be able to tell until I get a replacement servo. I placed the receiver in a balloon on the Zelos so hopefully when I run again it won't be an issue.
Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda -
I was hoping that wouldn't be the case but don't mind doing it if it will keep it out. I did a short video of where the smut is coming out from using the contact cleaner. Will post shortly.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
I would say about about 1/4 to 1/2 cup of water gets in. Usually sits in the back near the 4 bolts for the struts. Do you thing spraying plasti dip on the inside around those nuts would help or just silicone all the nuts?Man my buddy runs the sr310 receiver in 2 of his boats, which have been completely swamped and get a little wet occasionally and he has never had one go bad. How much water exactly are you getting in the boats? A few drops? A tablespoon? A cup? 5 cups? I would pressure check the cooling systems, and set them in a bathtub to make sure you don't have water coming through any of the hardware. I find it hard to believe those receivers are going bad if they are getting slightly wet, they are made toProboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
Last edited by Keagan-Z06; 05-27-2016, 03:25 PM.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
Those drives are a 6 piece design. They just need to be tightened up, just don't over tighten them or you'll crush the plastic socked washers that the strut ball sits in. You don't need to remove the base off the hull. Just the 3mm adjustment bolt and then use an open end wrench to loosen the nut that holds the strut to the base.Rafael Lopez
Product Developer-Pro Boat
My Facebook https://www.facebook.com/profile.php?id=100010183246751Comment
No pics of the goo pad, its about twice as dense as bubble gum and should just wipe off with a finger. Silicone should do about the same thing. As far as waterproofing, the plasti dip is just my take on it. Dont take my word over these guys they have waaaayy more experience than I do. Im a guppy in this pond.Comment
I've found plasti dip shrinks over time and tears holes in itself. Use two part epoxy. Not a ballon, that just looks horrible. Epoxy. Do it. What have you got to lose? Evidently doing nothing isn't helping. Just make dure the epoxy covers the pins that stick out the bottom of the circuit board and pack some dielectric grease in the plugs.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Will do, unfortunately I'm stuck here at working with the Zelos on my mind. River about a mile away... uggghhh!I've found plasti dip shrinks over time and tears holes in itself. Use two part epoxy. Not a ballon, that just looks horrible. Epoxy. Do it. What have you got to lose? Evidently doing nothing isn't helping. Just make dure the epoxy covers the pins that stick out the bottom of the circuit board and pack some dielectric grease in the plugs.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
Quick request from any of you that have achieved over 65- 75 mph with your Zelos. I am thinking maybe I didn't sharpen the X447s enough, would it be possible for anybody to take pics of their props sharpened and balanced for comparison sake. I know I won't be able to tell the difference by pics only but its a start. I know arrover runs the X447s but any prop will do in this case.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
They will cut you if your not careful
Yeaaahhh mine looks nothing like that!
Will a post a photo when I get home.
Bench test your props after you balance them. Full throttle for 2 seconds; wont hurt a thing. Be extra cautious of the spinning props. If the drive/strut vibrates, the prop's not balanced.Rafael Lopez
