  • Keagan-Z06
    • Mar 2016
    • 970
    #1936
    Yup I'm thinking that after multiple runs of grease buildup, water (no leaks since I started using hockey tape) and constant pounding, it gave up. I didn't hit anything that I could of seen. The boat didn't react like it hit anything either
    • ChevyPrerunner
      • Jun 2015
      • 205
      #1937
      Ouch that looks painful Keagan, glad to hear you got her fixed up.
      • Keagan-Z06
        • Mar 2016
        • 970
        #1938
        Thanks Chevy, it will be back in the water hopefully next week.
        • banixj
          • May 2012
          • 107
          #1939
          Originally posted by kfxguy
          Lol
          why lol?
          HPR 115 kevlar bulletproof @90mph, MHZ Rapid carbonfiber, Bingo Race Minieco
          Futaba AIR TX/RX system with telemetry
          • banixj
            • May 2012
            • 107
            #1940
            what about cracks in this clip?
            • ChevyPrerunner
              • Jun 2015
              • 205
              #1941
              My Zelos developed lots of stress cracks in the paint on the bottom also. I added another layer of fiberglass and resin while I was in repairing the transom when I flipped into a curb lakeside.. nice and strong now but still has the paint stress cracks. probably nothing much to worry about other than looks..
              • Team Lucas
                • May 2016
                • 300
                #1942
                Waxing the bottom? Should wet sand it with 2000 grit so it doesn't suck to the water.
                Zelos 36 stock 68 mph
                • ray schrauwen
                  • 9471
                  #1943
                  The sloppy rudder bushing is a good opportunity for someone to make an upgrade part. Don't mean to be negative however, the strut bushings would wear similarly fast in Geico's and the only reason why I can think it happens is because of the material used is too soft.
                  Is this common to many of these boats?
                  • stratus
                    • Dec 2016
                    • 110
                    #1944
                    On mine has that play from like the start that I got the boat
                    Genesis 36", Zelos Twin 36"
                    • REDLINE1
                      • Jul 2016
                      • 199
                      #1945
                      Mines is doing the same thing. In all fairness I think it happened when I recently flipped my Zelos. The area in the center under the battery / electronics tray flexes pretty good on my hull. That area carries a decent amount of weight with 4 batteries. I think when mine landed (good side up) the weight of the batteries flexed that center section and caused the gelcoat and paint to crack. I'm also adding a few layers of CF cloth to that center section under the battery tray in hope of stiffening it up some. Also putting a some in back in the strut area and adding the 1/16" CF plate under each strut in back like Keagan did . As for the spider cracks I may lay some flat black vinyl down the center on the bottom to cover them up and seal it from the water
                      • Keagan-Z06
                        • Mar 2016
                        • 970
                        #1946
                        Originally posted by MADRCER
                        You need a setup like this and it will take the 1hr removal and 3hr installation of the motors out of your equation.
                        [ATTACH=CONFIG]151704[/ATTACH]
                        Ok where can I get that tool??
                        • fweasel
                          master of some
                          • Jul 2016
                          • 4285
                          #1947
                          My bushing does not noticeable play in it.
                          • stratus
                            • Dec 2016
                            • 110
                            #1948
                            The cheapest i could find on ebay http://www.ebay.com/itm/332166085519...%3AMEBIDX%3AIT
                            • Keagan-Z06
                              • Mar 2016
                              • 970
                              #1949
                              Thanks fellas!
                              • fweasel
                                master of some
                                • Jul 2016
                                • 4285
                                #1950
                                First run of the season. Had the struts set at about 2.5mm with ABC 1814 props and 4 3S packs. Had a little too much hop on the first run and never really got many WOT passes. GPS read 67.5mph. Took out the HRB packs and put a set of Revo's 70C graphenes in. Second run was better, smoother down wind, but still not a lot of WOT because I didn't want to flip it today. I did flip it pretty good once, more of a sideways cartwheel, and landed business side down. Ran 71.6mph, but the temps came back really warm. The motor connectors melted the hatch foam and there was a lot of smoke, on both runs. It was alarming at first, but I knew as soon as there was no smell, it wasn't the electronics. I borked one of the struts on the flip to nearly full positive trim angle. Funny, I didn't really notice it much on the few passes I made after the flip before I brought it back. Next trip I'll use an air dam and run the struts at 3mm.
